Building a Zynthian Box using an official Kit v2
Zynthian Shop
Specifically, the instructions are for the assembly of kits v2 (version 2), those using the All-In-One circuit and the PiScreen 3.5' display. If you have an older kit v1, based in the 2in1 circuit and the PiTFT 2.8' display, you better should read this tutorial.
Anyway, the instructions are quite detailed and can be used as inspiration for building a custom Zynthian Box from scratch. Of course, you will have to be creative if you want to do it in such a way ;-)
2 Bill of Materials
- Zynthian Basic Kit (custom PCBs, electronic parts, wiring and knobs) Visit the Zynthian Shop
- Case kit, including nuts, bolts and connectors. Visit the Zynthian Shop
- Raspberry Pi 3 (or Raspberry Pi 2)
- HifiBerry DAC+ souncard
- OzzMaker PiScreen 3.5" touch-display
- 16GB SD Card (a good one, please!)
3 Some definitions
3.1 Zynthian
3.2 Zynthian Software
+ GNU Linux Operating System: Raspbian Jessie (Minibian is used in the most recent SD images) + Jack Audio Daemon + MOD-HOST + MOD-UI software, from ModDevices (github repositories) + A collection of standalone Synth Engines & LV2 Plugins (see Supported Synth Engines & Plugins) + Zynthian User Interface (github repository)
What is Free Software?
After downloading the SD-image, you have to write it to a micro-SD card. You need a micro-SD card with a minimum size of 16 GB, although you can use a bigger one if you want.
If you don't know how to do it, you can use Etcher (free software works on Mac, Windows or Linux) to flash the image onto the micro-SD card. Or do it manually! There is a really good manual for this at this link.
3.3 Zynthian Box
3.4 Zynthian Kit
A Zynthian Kit is a set of specific and generic electronic modules designed or picked for building a Zynthian Box. This tutorial refers to the official Zynthian Kit v2, that is composed of these specific parts:
+ 4 x Controller Modules (rotary encoder + switch) + 1 x All-In-One Module (GPIO expander + MIDI IN/OUT/THRU) + 1 x Main ribbon bus cable + Wiring Kit with JST connectors
and these generic parts:
+ 1 x Raspberry Pi 2/3 + 1 x Hifiberry DAC+ (also pro & lite) + 1 x PiScreen 3.5' Touch-Display
- A build with variations, by vagnscott - Another Wiring, by Imager - Success Cases
3.5 Zynthian Case
It's the enclosure used to put on all the parts. Again, this tutorial refers to the official Zynthian Aluminum Case v2, that is designed to be used in conjunction with the official Kit v2.
4.1 Prerequisites
4.1.1 Required Skills
4.1.2 Tools
+ Soldering iron + Tin-solder + Wire-cutter + Small Plier + Screw-drivers Philips + Wrench, for potentiometer nuts (recommended) + PCB holder for soldering (very recommended!) + Small iron brush (very recommended!) + Magnifiying glass (recommended) + A vice (recommended) + A hand saw for metal (recommended) + Multimeter (recommended!)
3. When soldering, always avoid overheating. Electronic components doesn't like overheat! This is specially important when soldering the big connector in the HifiBerry soundcard. If you overheat the circuit, probably you will break some electronic component and you will end with a dead board. I recommend to use a fan while soldering. If not, you can use your mouth ;-) Also, don't solder the contacts in order. It's better to jump from one to another in the oposite corner. If you are not sure of your soldering skills, please, take your time and do some practice with inexpensive components and prototyping board.
6. And of course, double-check everything! Assembling and wiring process are prone to errors. Don't be too confident ;-) Re-check component's orientation (ICs and diode), wiring, etc.
+ 4 x controller PCBs + 4 x rotary encoders with switch (PEC11R-4215K-S0024) + 4 x ceramic capacitor 100nF (C1) + 8 x ceramic capacitor 10nF (c2, c3) + 4 x 4-pin JST male-angle connector
This components are used to build the 4 controller modules that form the input side of the physical Zynthian User Interface. Each controller embed an incremental rotary encoder and a switch, so 4 wires (A,B,SW,GND) are needed for connecting it.
0. Be sure that you have read and understdood these recommendations. 1. Bend the encoder's securing tabs to 75º, so you can insert it in the upside of the PCB (the labeled side!). Please, be very careful when bending the tabs as the encoder case is quite fragil and could be deformed. I recommend to use a small plier and not reaching to 90º. 2. Place the 100nF capacitor in C1 position (the most right!). This is for debouncing the push switch (SW). 3. Place the 2 x 10nF capacitors in C2 & C3 positions. These are for debouncing the rotary encoder contacts (A,B). 3. Solder the encoder and capacitors carefully. 4. Place the JST connector in the downside of the PCB, with the angle pins facing inwards (look the photo!) 5. Solder the JST connector carefully. 7. Use the plier to close the encoder's tabs again, trying to "catch" the PCB.
4.4 Assembling the All-In-One Module
The All-In-One module kit is composed of:
+ 1 x All-In-One PCB + 1 x GPIO-expander MCP23017 => 28-pin IC + 3 x opto-coupler H11L1 (OC1,OC2,OC3) => 6-pin IC + 3 x diode 1N4148 (D1,D3,D4) + 1 x diode 1N5819 (D2) + 3 x resistor 1K (R3,R4,R9) => brown-black-red (*) + 1 x resistor 10K (R10) => brown-black-orange (*) + 1 x resistor 100 (R1) => brown-black-brown (*) + 2 x resistor 4K7 (R5,R7) => yellow-purple-red (*) + 3 x resistor 470 (R2,R6,R8) => yellow-purple-brown (*) + 4 x ceramic capacitor 100nF (C1,C2,C3,C4) + 7 x 4-pin JST male connector + 1 x 40-pin-double-row male connector
These are the steps for building the All-In-One module:
0. Be sure that you have read and understood these recommendations. 1. Place the passive components (resistors & capacitors) in the upside of the PCB (the labeled side!). 2. Solder the components carefully. Always avoid overheating! 3. Place the ICs and diodes in the upside of the PCB (the labeled side!). Put attention to the orientation of these components!! 4. Solder the components carefully. Always avoid overheating! (*) 5. Place the connectors in the upside of the PCB (the labeled side!). 6. Solder the components carefully. Always avoid overheating! (*)
(*) You could use some tape for fixing the components while soldering, specially for ICs and connectors.
4.6 Tweaking the OzzMaker PiScreen 3.5' touch-display
The standard OzzMaker PiScreen 3.5 'touch-display have 2 connectors: a female connector ready for connecting the display as a hat and a male connector placed in the side. The official aluminum case and the ribbon cable are designed for the side male connector. The female connector can be annoying and should be removed for better closing the case.
If you got your PiScreen from a "Bundle-All" kit, you probably don't have this annoying female connector, so you are lucky and don't need to do anything here. If you have it, then take the saw and remove the connector carefully.
4.8 Building the MIDI-IN/OUT/THRU connectors
Before mounting the MIDI-IN/OUT/THRU connectors into the case we will solder the needed wires that allow connecting it to the All-In-One circuit using a JST connector. Doing it in that way is rather more comfortable than trying to solder inside the case with all the wiring mess.
JST Connector wires
* JST White (1) => LED's Anode (LED's red wire/long lead) * JST Yellow (2) => LED's Cathode (LED's black wire/short lead) * JST Black (3) => pin 5 of MIDI connector * JST Red (4) => pin 4 of MIDI connector
If you want (I strongly recommend you do it!), you can protect the contacts using heat-shrink sleeve (the red sleeve pieces in the photo). In that case, remember to insert the sleeve pieces before soldering ;-)
Depending on your case version, you will need to build 2 or 3 MIDI connectors.
5 Case Mounting
5.3 Secure the All-In-One module
Secure the All-In-One module to the case using 4 x separators and 8 x M2.5 bolts.
5.5 Secure the MIDI-IN/OUT/THRU connectors
Just insert the connector with the JST-wire from the out-side of the case and the nut from the innerside. A pair of pliers can be useful for tighten.
5.6 Mount the MIDI activity LEDS
Insert the 3 LEDS in the case holes. You may want to push the LEDs with something more rigid than your finger. The screwdriver's handle could be fine.
When it's done, you have to solder the 2 LED wires (red/black) with the 2 spare wires on the MIDI JST harness (white/yellow). Polarity is important, so don't cross the wires:
* JST White wire (1) => LED's Anode (LED's red wire/long lead) * JST Yellow wire (2) => LED's Cathode (LED's black wire/short lead)
After soldering all the 3 LEDs, you may want to protect the connection with heat shrink sleeve, adhesive tape or hot melt glue.
5.7 Secure the Display
It's composed of 4 bolts, 4 nuts and 4 nylon separators. Before fixing the screen, don't forget to remove the protective plastic sheet.
5.8 Secure the Controllers
Fix the 4 controller modules to the case cover using the 4 bolts and washers attached to every rotary encoder.
IMPORTANT: For avoiding problems while closing the case, i recommend to mount the controller modules with the connectors facing one another. See the photo below.
5.9 Insert the knobs
* moisten with water or saliva the encoder stem and the knob hole * press the encoder PCB with the finger from the rear side while pushing the knob from the front side until is completely inserted
5.10 Stick the rubber feet
6 Connecting everything
The new Zynthian Kit 2 is designed to use JST connectors, so connecting everything is really straight-forward:
6.1 Connect the Ribbon Bus cable
Connect the Main Ribbon Bus cable to the RBPi's 40-pin header and also to the All-In-One module
6.2 Connect the controllers (1)
Connect the 4 double JST cables to the 4 controller connectors on the All-In-One module (CTRL1, CTRL2, CTRL3, CTRL4)
6.3 Connect the MIDI connectors & activity LEDs
Connect the 2 JST cables from the MIDI connectors to the MIDI-IN and the MIDI-OUT/THRU connectors on the All-In-One module. Note that currently only 2 connectors are available in the official aluminum case, so you have to choose what do you prefer: MIDI-OUT or MIDI-THRU ;-)
6.4 Connect the controllers (2)
Connect the 4 x Controller Modules following the right numbering: from top to bottom and from left to right.
6.5 Connect the Audio Jack connectors
Connect the Jack connector to the auxiliar audio-out connector on the HifiBerry soundcard. It's the 3-pin JST connector that you soldered before:
At this point, if you have a v2+ kit (HifiBerry DAc+ADC soundcard with audio input), you should take a look to the v3 kit instructions.
6.6 Connect the Display
And finally, connect the ribbon's 26-pin connector to the Display's male side connector. Put attention to the orientation. The red wire should be the pin 1 that as marked in the display's PCB surface.
7 Testing your Zynthian Box
7.2 First Boot
1. Insert the SD-card with the zynthian image ready to run. If you don't have one yet, read this. You can insert the SD-card through the "window" on the bottom-side of the case. Also, if the case is still open, you can do it from the top. 2. Plug the mini-usb power connector. A good 5V micro-usb charger is recommended (> 2 Amp).
If you don't get an error screen or a blank screen, bad luck! Probably you made some mistake during the mounting process. You have to locate and solve the problem(s).
If you are using the Aruk RC-3 SD image (you should!), you are lucky because this SD image is pre-configured for working with the kit v2. If not, perhaps you need to configure the software for working with the kit v2. The simplest way of doing it is using the webconf tool:
- From your web browser, access the zynthian's webconf tool by typing "zynthian.local" in the address bar. If this doesn't work for you, you should try with the IP. You can get the IP of your zynthian by navigating to the Admin Menu and clicking "Network Info". You should do that by using the "touch" interface: Click the top bar with a stick (or your nail, if it's not too wide) until you are in the Admin Menu. Once you are there, go down and click "Network Info".
- Type the password (raspberry) for login into the webconf tool.
- Once you are logged in, you have to access Hardware->Kit and select "Kit V2".
If you are using a really old SD image (you shouldn't!) that is not pre-configure for the Kit v2, then you have to specify every part of your hardware configuration. These are the adjustments you have to set:
- Display: PiScreen 3.5 (v2)
- Audio: HifiBerry DAC+ / HifiBerry DAC+ADC
- Wiring: MCP23017_EXTRA
- Style: FontSize = 14
7.3 Test the Controllers & UI
You should get into the 'Instrument Control' screen.
If everything is working OK, then you should read the User's Guide and start enjoying your Zynthian Box, but before that ... why not enjoying a little bit? Connect your MIDI keyboard, your speakers and check this out:
Keep pushing a single note (or a chord) and move the cutoff and resonance controllers. Enjoy! ;-)
7.4 Test the Audio Output
1. Connect the audio output (RCA or Jack connectors) to your amplifier or auto-amplified speakers. 2. Boot your Zynthian. You should be in the initial 'Layer Selection' screen. 3. Push BACK and you will get into the 'Admin' screen. 4. Select 'Audio Test' option and push 'SELECT'. You should hear the test audio-track: a nice afrocuban stuff ;-) 5. Push 'BACK' to stop the playing, and 'BACK' again to return to the "Layer Selection' screen.
7.5 Test the MIDI subsystem
2. Boot your Zynthian, select FluidSynth engine, channel #1 and 'TimGM6mb' bank. Select some instrument, like "Piano 1".
3. You could add more layers for completing the band ;-)
4. Select 'MIDI Test' option and push 'SELECT'. You should hear the test midi-track ('Take Five') interpreted by your Zynthian's band ;-)
7.6 Test the MIDI-USB inputs
1. Connect the audio output (RCA or Jack connector) to your amplifier or auto-amplified speakers. 2. Boot your Zynthian, select ZynAddSubFX, channel #1, bank and instrument 3. Connect a MIDI-USB keyboard to any USB port. The keyboard should be configured to use channel #1. 3. After 2-3 seconds , play something with your keyboard. A simple Chopin's Nocturni would be enough. You should hear your music. If you don't like it, probably you should take some piano lessons, same as me ;-)
1. Connect the audio output (RCA or Jack connector) to your amplifier or auto-amplified speakers. 2. Boot your Zynthian, select ZynAddSubFX, channel #1, bank and instrument. 3. Connect your keyboard's MIDI-OUT to the Zynthian's MIDI-IN using a MIDI cable. 3. After 2-3 seconds, play something with your keyboard. OK! A single melody can do the task. You should hear your song ;-)
8 Final steps
8.1 Close the case
Take your time to see how to bend and drive the cables to get a good fitting when closing the case.
9 Update your Zynthian Box
The update process can take some time. Be patient. If you get some ERROR message while updating, please, ask in the forum. You can send a photo or description of the error message.
10.1 The display don't show the zynthian splash screen on boot
10.2 You get the zynthian error screen with the IP
10.3 Your controllers doesn't work
11 Technical Reference
11.1 All-In-One Schematic
This is the electrical scheme of the All-In-One circuit:
