Command Line User Guide
1 SSH/SFTP access:
login: root
password: raspberry
Note: on the new Bookworm (64bit) image, still in development, the password has changed to opensynth.
If you use ssh from the linux/mac terminal, it's so easy as:
ssh root@zynthian.local
or
ssh root@zynthian.lan
  • User pi doesn't exist any more
  • It's a good idea to change the password, specially if your zynthian is connected to public networks. You can do it easily from the webconf.
2 Base Directory:
/zynthian
Most of zynthian stuff is in this directory.
You must use systemd-style commands to stop & start any system service. For the zynthian UI you would use:
systemctl stop zynthian
systemctl start zynthian
If you want to run the Zynthian UI in the console, you must stop the zynthian service and run the zynthian UI as a normal script using these commands:
zynthian.sh
Running zynthian from the console (terminal) allows you to view the detailed debug messages, which is convenient for solving issues. Posting these to the forum will enable experts to help you. You can also access the UI log messages from the webconf.
systemctl stop zynthian-webconf
systemctl start zynthian-webconf
If you need access the webconf's log messages, you can use:
journalctl -u zynthian-webconf
5 Configuration without WebConf
If you can't access WebConf with a browser, you may edit this file:
# zynthian_update_sys.sh
6 Viewing the Zynthian graphics display on a computer
 ssh -Y root@zynthian.local
this will allow you to run graphic applications in your Zynthian, while displaying the graphics window on your PC/laptop.
7 Useful zynthian command line commands
aconnect -l        list MIDI connections (that ALSA knows about)
aplay -l           lists audio hardware devices (that ALSA knows about)
aplay -L           lists the ALSA device names of all hardware and software devices
alsamixer          graphical mixer program for the ALSA that is used to configure sound settings and adjust the volume
aseqdump           show the events received at an ALSA sequencer port
jack_lsp -c        lists connections to/from each JACK port
lsusb              list known USB devices
lsof               list of all open files and the processes that opened them.
patchage           graphical modular patch bay for audio and MIDI systems based on JACK and ALSA
gpioinfo           to see current GPIO status
scrot              to take screenshots
export DISPLAY=:0  set which display is to be used
8 Create screenshot
1. Access to your Zynthian
2. If first time you create screenshot
3. Take the screenshot
4. The screenshot will be in the root folder of your Zynthian
9 More detailed info
