Building a Zynthian Box using an official Kit v3
Jump to: navigation, search
Introduction
Zynthian Shop
Bill of Materials
  • Raspberry Pi 3
  • HifiBerry DAC+ADC souncard
  • 16GB SD Card (a good one, please!)
Some definitions
Zynthian
Zynthian Software
+ Jack Audio Daemon
What is Free Software?
Download Zynthian "Aruk RC-3" SD-image
If you don't know how to do it, you can use Etcher (free software works on Mac, Windows or Linux) to flash the image onto the SDcard. Or do it manually! There is a really good manual for this at this link.
Zynthian Box
- Zynthian Case Repository
Zynthian Bundle All Kit v3
A Zynthian Kit is a set of specific and generic electronic parts. This tutorial refers to the official Zynthian Bundle All Kit v3, that is composed of these specific parts:
+ 1 x Main ribbon bus cable
these generic parts:
+ 1 x Raspberry Pi 3
+ 1 x Hifiberry DAC+ADC
and the aluminium case:
+ 1 x Zynthian Aluminium Case
+ 1 x Connectors
+ 1 x Bolts & Nuts
Unboxing the Official Kit V3, by Sébastien Marty
Assembling your Zynthian Box
Prerequisites
Assembling your Zynthian Kit V3 is not difficult at all: you need your attention, a screwdriver and an adjustable wrench. The kit v3 is a pre-built kit and you don't need to solder anything, just screwdrive the bolts and plug the wires.
Please, handle electronic parts with care, specially the display, as it's easy to damage.
Secure the Jack connectors
Insert every connector from the inner-side of the case and the ring washers and nuts from the outer-side. The ring-washers will avoid damaging the case surface when you tighten the nuts. A wrench or pair of pliers can be useful for tightening the nuts.
Secure the MIDI connectors
Just insert every connector with the JST-wire from the outer-side of the case and the nut from the inner-side. A wrench or pair of pliers can be useful for tightening the nuts.
Mount the MIDI activity LEDS
Insert the 3 LEDS in the case holes, leaving the short lead at left. Don't push the LED's head! Instead push the black plastic holder around the LED. Sometimes is hard to push ...
As the LED's leads are too long, you would like to cut them a little bit (7-8 mm is a good length), but remember where the "short" lead is located!!
Assemble the Main Computing Block
1. Fix the 2x4 separators to the RBPi. The bigger one must be on top and the smaller one on bottom.
2. Insert the Hifiberry soundcard in the RBPi.
3. Screwdrive the 4 bolts on top of the HifiBerry.
Secure the Main Computing Block
Secure the Zynaptik module
Secure the Zynaptik module to the case using 4 x separators and 8 x M2.5 bolts. I recommend to start fixing the separators to the case.
As you can see, the zynaptik circuit has some extra circuitry that is not soldered on it by default. Don't worry about it because it's not needed at all for building a fully functional standard Zynthian Box.
Secure the Display
It's composed of 4 bolts, 4 nuts and 4 nylon separators. Before fixing the screen, don't forget to remove the protective plastic sheet.
Secure the Controllers
Plug a wire on every controller.
Fix the 4 controller modules to the case cover using the 4 bolts and washers attached to every rotary encoder.
Insert the knobs
Stick the rubber feet
Connecting everything
The Zynthian Kit 3 is designed to use JST connectors that can't be plugged reversed, so connecting everything is really straight-forward:
  • Connect the Main Ribbon Bus cable to the RBPi's 40-pin header and also to the Zynaptik module. The red wire is pin 1, so if you are looking at the case from the front side, it should be at right.
  • Connect the 4 controller cables to the 4 controller connectors on the ZynScreen (CTRL1, CTRL2, CTRL3, CTRL4)
  • Connect the 3 cables from the MIDI connectors to the MIDI-IN, MIDI-OUT and MIDI-THRU connectors on the Zynaptik module.
  • Connect the audio output jack connectors to the audio-output header on the Hifiberry soundcard:
  • Connect the balanced audio input jack connector to the audio-input header on the Hifiberry soundcard:
Connect the Display
And finally, connect the ribbon's 26-pin connector to the display's connector. Put attention to the orientation. The red wire should be the pin 1 that as marked in the display's PCB surface.
Building and Testing the Official Kit V3, by Sébastien Marty
Testing your Zynthian Box
Double-check part's assembling and wiring
First Boot
1. Insert the SD-card with the zynthian image ready to run. If you don't have one yet, read this. You can insert the SD-card through the "window" on the bottom-side of the case. Also, if the case is still open, you can do it from the top.
If you don't get an error screen or a blank screen, bad luck! Probably you made some mistake during the mounting process. You have to locate and solve the problem(s).
  • From your web browser, access the zynthian's webconf tool by typing "zynthian.local" in the address bar. If this doesn't work for you, you should try with the IP. You can get the IP of your zynthian by navigating to the Admin Menu and clicking "Network Info". You should do that by using the "touch" interface: Click the top bar with a stick (or your nail, if it's not too wide) until you are in the Admin Menu. Once you are there, go down and click "Network Info".
  • Type the password (raspberry) for login into the webconf tool.
Test the Controllers & UI
You should get into the 'Instrument Control' screen.
If everything is working OK, then you should read the User's Guide and start enjoying your Zynthian Box, but before that ... why not enjoying a little bit? Connect your MIDI keyboard, your speakers and check this out:
Keep pushing a single note (or a chord) and move the cutoff and resonance controllers. Enjoy! ;-)
Test the Audio Output
Test the MIDI subsystem
2. Boot your Zynthian, select FluidSynth engine, channel #1 and 'TimGM6mb' bank. Select some instrument, like "Piano 1".
3. You could add more layers for completing the band ;-)
4. Select 'MIDI Test' option and push 'SELECT'. You should hear the test midi-track ('Take Five') interpreted by your Zynthian's band ;-)
Test the MIDI-USB inputs
3. After 2-3 seconds , play something with your keyboard. A simple Chopin's Nocturni would be enough. You should hear your music. If you don't like it, probably you should take some piano lessons, same as me ;-)
Test the MIDI-IN connector
Final steps
Close the case
Take your time to see how to bend and drive the cables to get a good fitting when closing the case. The ribbon bus cable is pre-bended for easing this process.
Update your Zynthian Box
The update process can take some time. Be patient. If you get some ERROR message while updating, please, ask in the forum. You can send a photo or description of the error message.
Locating and Solving problems
The display don't show the zynthian splash screen on boot
You get the zynthian error screen with the IP
Your controllers doesn't work
You can't solve the problem
Technical Reference
Zynthian controller single2 smd.svg
Zynthian zynaptik.svg
ZynScreen v1.3.svg
