Zynthian FAQ
Jump to: navigation, search
LINUX Audio terminology is confusing
Understanding LINUX Audio Help in understanding all those acronyms mentioned in this Wiki
What RaspberryPi does Zynthian support?
You need a RBPi3 Raspberry Pi 3 Model B or Raspberry Pi 3 Model B+
RBPi2 is not longer supported by official zynthian SD images. If you want to use a different RBPi version, you should rebuild your own SD image. Also, you can try with the experimental ZynthianOS images from here:
https://os.zynthian.org
Where can i buy a Zynthian Kit?
Currently you can buy the official Zynthian Kits in the Zynthian Shop.
How do I edit entries in the wiki?
I just wrote my 16/32/64 GB SD card with a Zynthian image, but from Zynthian's console i only see a part of SD's total space and i've no free space left in the partition. How can i make available all the space on my SD Card?
+ reboot your zynthian box
+ login again and execute "df" command to see size of your partition and the available space. You should see the difference ;-)
I have a license for Pianoteq 6, what would be the process to enter the license key ?
Does the pre-built kit come with a RBPi3 or 3+ ?
Bundle All Kits come with a RBPi 3+. Check the shop's product descriptions:
 http://shop.zynthian.org/shop/category/zynthian-v2-basic-kits-4
I’m primarily a guitarist and thus, I’m interested in the MOD UI.
I know some people have experimented with audio input and was wondering if this would be added to the “official” Zynthian kit at some point and if so, how hard would it be to “upgrade” to it ?
We are working for adding "audio input" to official Zynthian Kits. We hope to release the new kits by spring/summer of 2019.
Do you think Zynthian is for me ?
Knowing that I am comfortable with tinkering (basic soldering, basic command line in linux) and that the idea would be to use Zynthian in a professional environment (studio and on stage)
About Zynthian Security
Everybody wanting to connect his Zynthian to a “not secure” network (every network not controlled by himself should be considered “not secure” :wink: ) SHOULD CHANGE the default zynthian password. You can do that from the webconf tool.
  • Although the Webconf Tool ask for the password, currently, it doesn’t use HTTPS, so your password could be sniffed by bad actors connected to the local network. That is specially true if you are using an ethernet cable or the old WEP Wifi protocol. If you are using WPA2 Wifi protocol in your 2 devices (Zynthian and your “computer”), then you should be protected against sniffers.
  • When a MOD-UI layer is created in zynthian, the MOD-UI server run completely open for everybody in the local network.
  • IMHO, these 2 are the main security holes in Zynthian. For solving it, we have to:
  1. Use HTTPS for webconf tool.
  2. Secure the MOD-UI server:
