Zynthian Users Guide
1 Main Guides - Start Here
- Zynthian UI User's Guide - Oram (incomplete but frozen): Oram is the current stable version.
- Zynthian UI User's Guide - Vangelis (work in progress): Vangelis is the development version.
- Assistive Technology and accessibility - Vangelis: A guide of Vangelis accessibility features.
- Learning Pills - Vangelis: Short tutorials, usually under 5 minute view / listen / read.
- ZynSeq User Guide: Zynthian's built-in step sequencer.
- ZynSampler User Guide: Zynthian's built-in non-destructive audio sampler.
2 Hardware Guides - Midi Controllers
- Supported plug & play MIDI controllers: Zynthian has default mapping configs for Novation, Akai, Korg and other controllers...
3 Software Configuration Guides
- Web Configuration User Guide: Zynthian's built-in web interface, also known as webconf.
- Command Line User Guide: If you need to manually setup/configure things.
4 Engines/Plugin Specific Guides
There are some guides on specific engines available in Zynthian. They cover topics such as configuration, managing and importing presets etc. Some of them are listed below, for a full list see Engines#Zynthian Native Engines
- DrumGizmo Open source, multichannel, multilayered, drum plugin
- GeonKick Free software for generating a wide range of percussive sounds
- Perfomix Automated build-up audio effects with looper function.
- Drum Kits as LV2 plugins
- SooperLooper Flexible audio looper with functionality similar to the Echoplex Digital Pro
5 Un-official Guides
6 Legacy Guides
- Legacy Zynthian UI - V5 User Guide (old stable-2401)
- Legacy Zynthian UI - V1/V4 User Guide (old stable-2401)
- Legacy Zynthian UI User Guide (old stable-2109)
7 Advanced Guides
- Zynthian Hardware: Using custom hardware with Zynthian for DIY setups (audio, displays, rotary encoders etc.)
- Adding Extra I/O with the Zynaptik Module: Adding the Zynaptik extra I/O Option
- Adding LV2 plugins: Adding LV2 plugins to the system.
- MIDI Network: Receive/Send MIDI with RTP-MIDI & QMidiNet
- Understanding LINUX Audio: will help you understand the acronyms mentioned in this Wiki
- Aligning Zynthian Touchscreens: Guidance for non-standard Zynthian screens. (Update: For reference, touchscreen calibration now available within the UI)
8 Beginners
- First Steps: A brief tutorial on basic UI usage for Version 3
- Quick Start: A beginners tutorial on how to make a piano snapshot
- Making some sounds: A beginners tutorial on how to make your Zynthian make some sounds
9 Video Guides
9.1 English
9.2 French
