Zynthian Updating
1 Important notice
Zynthian runs on top of a basic Debian Linux system. It is not recommanded at all to do the traditional "apt-get update & apt-get upgrade" commands: this could break your Zynthian system.
You have been warned !!!
If you are using an official Zynthian SD Image, after booting up your Zynthian Box, you probably may want to update the software to get the latest fixes and improvements.
2 Updating from the UI
If your Zynthian's UI is working OK and you can control the interface using the knobs or the touch screen, you can update your software very easily:
  1. Connect your Zynthian Box to your router/switch using an Ethernet RJ45 cable. Alternately, you can configure the WIFI connection using the Webconf tool.
  2. Click update software from the UI's Admin Menu
  3. Click restart UI (or reboot) from the UI's Admin Menu. Your zynthian should do this automatically, so most probably you don't need to do this step by hand.
Please, note that using WIFI connection for updating is not recommended. If your connection is not stable this could break your system.
3 Updating from the Browser (webconf)
You can also update your zynthian from your browser, using the Webconf tool that should be available at one of these addresses:
 http://zynthian.local
 http://zynthian.lan
or
 http://#ZYNTHIAN_IP#
You can see the zynthian's IP in the admin menu -> network info.
4 Updating from the CLI
Finally, you can update from the command line, using this command:
 update_zynthian.sh
 Accessing Zynthian from other devices
