Zynthian UI User Guide - V5
- adjusting parameters
- the big 5x4 silicone button grid, that adds 20 push buttons with RGB LED feedback.
- as a consequence of the availability of more buttons, the 4 knobs are often used in quite a different way.
1.1 The Title Bar
1.2 The Status Area
- Digital audio Peak Meter (DPM): horizontal bars indicating digital audio level and peaks
- Status Icons: indication of various zynthian states
Let's see the details:
1.2.2 The Status Icons
| 1st row: Health & Load | ||
2.1 Chains
The chain's type can't be changed. Depending on the chain's type, MIDI processors can be added to the start of the chain and audio processors can be added to the end of the chain. Chain processors can be re-ordered and arranged as serial and / or parallel paths.
3 Using the push buttons
3.1 Screen access buttons
- Mixer
- Chain Control (Instrument)
- Preset/Bank
- SubSnapShots (ZS3s)
- Tempo screen / Tap-Tempo
- Scene (ZynPad)
- Pattern
3.2 ALT button
3.3 Transport buttons
Pattern editor screen
Audio-player chain
- Up/Down arrow buttons:
- Browsing lists and menus.
- Left/Right arrow buttons:
- Select/Yes button:
- Back/No button:
4 Using the knobs
4.1 General rule
- Knob#1 - #4
4.3 Mixer
4.4 Scene (ZynPad)
4.5 Pattern
5 The UI Screens
6 Learning Pills
6.1 Basics
6.2 Sequencer
6.3 Mini-HowTos
7 Work In Progress
