ZynSeq User Guide
This guide explains how to access and use the Zynthian's step sequencer called, ZynSeq. Before following the guide, add 2 synth engines to layers using MIDI channels 1 & 2 respectively. We will use these to demonstrate ZynSeq. If you use a touchscreen instead of rotary encoders then enable touch widgets using webconf INTERFACE->UI Options. See User Interface Settings for Touchscreen/Headless Setups for more info.
Pattern
A pattern is a collection of MIDI events, e.g. notes. Each pattern has a duration in steps and may include as many simultaneous (polyphonic) notes as desired on each step. We will see how patterns are manipulated in the Pattern Editor section
Track
A track contains a pattern or collection of patterns which may be played and looped. Each track plays out to its own MIDI channel. We will see how sequences and tracks are manipulated in the Arranger section.
Sequence
Group
A sequence is a member of a group (indicated by its pad colour). Several sequences may be played simultaneously but those in the same group do not play concurrently.
2.1 Pad Layout
Each pad displays information split into an upper and lower part. The top part shows the current loop setting (loop all - see Sequence Modes), the midi channel of the track it will play on and the sequence identifier (A1). Currently the track uses midi channel 1 which is assigned the 'Poly Dreams' preset from the OB-xD instrument. The preset is used as the default name (it can be renamed) and shown in the lower part of the pad. This pad is currently empty, when the pad has content, a stop button icon will appear in the top right corner. When the pad has no sequence at all, it displays dark grey.
3 Menus and Parameters
3.1 Parameter Editor
4 Pattern Editor
4.1 Step sequences and the Step Grid
4.2 Navigating the Pattern Editor and Entering Notes
4.3 Preview, Pattern Duration and Resolution
5 Note Duration
6 Note Velocity
7 Scales and Drum Maps
  • Chromatic (piano keyboard)
  • Major
  • Minor
  • Blues
  • Blues pentatonic
Input Type Description
Loop Mode and Overdub
9 Playing a sequence
10 Multiple Sequences
11 Groups
12 Grid Size
13 Sequence Modes
Sequence play modes
Mode Description Icon
Loop all is the default mode.
14 Sequence Names
15 Tempo
16 MIDI channels
17 Scenes
18 Save / Load / Snapshot
19 External Trigger
Feedback tallies
State MIDI velocity
Stopped 3
Starting 5
Playing 1
Stopping 4
20 Arranger
Arranger showing default
20.1 Accessing Arranger View and Understanding The Layout
  • Sequence name, e.g. A1
  • Track number, e.g. 1
20.2 Navigating Arranger View
The pattern to be added is indicated by a number in the bottom left of the display. This may be changed by rotating the LAYER encoder. (Note: This differs from ZynPad where LAYER encoder changes the scene.) Tapping the bottom left number on a touchscreen will allow selection of the pattern if touchscreen widgets are enabled.
20.3 Adding Tracks and Adjusting Sequences
20.4 Mute and Play Mode Options
21 Time Signature
22 Metronome
23 Pattern Management
24 Import / Export MIDI Files
24.1 Export
24.2 Import
25 Timebase
26 User Interface Settings for Touchscreen/Headless Setups
26.1 Controlling the Interface With a Qwerty Keyboard or MIDI Device with CUIA: Callable UI Actions
27 Example Workflows
27.1 Live looping pads
27.2 Oneshot phrases
27.3 Linear song
27.4 Combined Linear Song and looping pads
27.5 Synchronisation
