Build a Zynthian
1 How to build a Zynthian
This manual is currently in development!
1.1 Disclaimer
1.2 Prerequisites
1.2.1 Required competences
- Soldering
1.2.2 Tools
- Screw drivers
- Soldering iron
- Tin-solder
- Side cutter
- Magnifiying glass
1.3 Hardware
1.3.1 Bill of Material
No | Shipper | Order no. | Description | Pieces | Price per piece [€] |
1 | http://www.reichelt.de | 1N 4148 | Planar Epitaxial Schaltdiode, DO35, 100V, 0,15A | 1 | 0,04 |
2 | http://www.reichelt.de | 6N 138 | OPTOKOPPLER | 1 | 0,58 |
3 | http://www.reichelt.de | RASPBERRY PI 2 | Raspberry Pi 2, 4x 900 MHz, 1 GB RAM | 1 | 37,50 |
4 | http://www.reichelt.de | RPI HB DAC+ RCA | HiFiBerry DAC+ RCA, Raspberry Pi Shield | 1 | 35,90 |
5 | http://www.reichelt.de | 1/4W 220 | Kohleschichtwiderstand 1/4W, 5%, 220 Ohm | 1 | 0,10 |
6 | http://www.reichelt.de | 1/4W 1,0K | Kohleschichtwiderstand 1/4W, 5%, 1,0 K-Ohm | 1 | 0,10 |
7 | http://www.reichelt.de | 1/4W 10K | Kohleschichtwiderstand 1/4W, 5%, 10 K-Ohm | 1 | 0,10 |
8 | http://www.reichelt.de | MKS-02 100N | WIMA Folienkondensator, Rm 2,5mm 100nF | 4 | 0,15 |
9 | http://www.reichelt.de | GS 18P | IC-Sockel, 18-polig, superflach, gedreht, vergold. | 1 | 0,32 |
10 | http://www.reichelt.de | GS 8P | IC-Sockel, 8-polig, superflach, gedreht, vergold. | 1 | 0,19 |
11 | http://www.reichelt.de | SL 2X25G 2,54 | 2x25pol.-Stiftleiste, gerade, RM 2,54 | 1 | 0,24 |
12 | http://www.reichelt.de | MAB 5S | DIN-Buchse, 5-polig | 1 | 0,24 |
13 (OPTIONAL) | http://www.reichelt.de | NTA 176 | 6,3 Mono-Klinken-Bu. auf Cinch-St. | 2 | 0,35 |
14 | http://www.reichelt.de | NT MUSB 2 SW | Micro-USB Steckernetzteil, schwarz, 5 V, 2 A | 1 | 8,40 |
15 | http://www.segor.de | MCP23008-E/P | MCP23008 8 port I2C-GPIO extender | 1 | 2,10 |
16 | http://www.amazon.de | Adafruit PiTFT 2.8" | Adafruit PiTFT Touchscreen Display, 2,8 Zoll, für Raspberry Pi Computer | 1 | 32,00 |
17 | http://www.ebay.de | 12mm Rotary Encoder Switch | Rotary Encoder with switch, 20 steps | 4 | 0,60 |
18 | http://www.ebay.de | Poti knob | Poti knob for Rotary encoder (Pos. 17) | 4 | 1,50 |
19 | http://blog.zynthian.org | Encoder PCB | PCB for encoders | 2 | 10,00 |
20 | http://blog.zynthian.org | 2in1 PCB | PCB for MIDI and GPIO extension | 1 | 10,00 |
21 | http://blog.zynthian.org | Main Bus Ribbon Cable | Raspberry Main Bus Ribbon Cable | 1 | 20,00 |
22 | http://blog.zynthian.org | Mini-ribbon cable | Mini-ribbon cable (6 pin female connector to 6 female jumper connectors | 3 | 3,00 |
23 | http://www.saturn.de | SD card | Samsung 32GB SD card | 1 | 14,00 |
24 | - | Short connector cables | Connector cables pin-female/pin-female for MIDI and external GPIO connector from 2in1 board | 4 | ??,?? |
25 | - | Multi-pin connector | 1x40pol.-Stiftleiste, gerade, RM 2,54 | 1 | ??,?? |
Notes:
1.4.1 Step 1: 2in1 modules
1.4.1.1 You need:
- 1 * 2in1 PCB (Pos. 20)
- 1 * diode 1N4148 (pos. 1)
- 1 * IC 6N138 (pos. 2)
- 1 * IC MCP23008 (pos. 15)
- 1 * 2in1 PCB (pos. 20)
1.4.1.2 HowTo:
1.4.2.2 HowTo:
- 1 x multi-pin 4 pins angle
- 1 x controller single PCB
1.4.3.2 HowTo:
1.4.4.1 You need:
1.4.4.2 HowTo:
1.4.5 Checking everything
Hint:
1.5 Connecting the cables
1.5.1 You need:
- 1 * Raspberry Pi 2 (Pos. 3)
1.5.3 TFT
1.5.4 2in1
Wire no. | Function | GPIO no. | Pin on Raspi no. |
1 | Vdc 3.3V | 3.3V | 1 |
2 | RxD | RxD | 10 |
3 | I2C SDA1 | 08 | 3 |
4 | I2C SCL1 | 09 | 5 |
5 | Vdc 5V | 5V | 2/4 |
6 | GND | GND | 6/9 |
Wire no. | Function | MIDI-IN pin no. |
1 | MIDI-IN | 2 (MIDI connector: 2nd from left) |
2 | MIDI-IN | 4 (MIDI connector: 2nd from right) |
PHOTO NEEDED HERE!!
1.5.5.1 Controller 1
1 | Enc1-B | 25 | 37 |
2 | Enc1-A | 27 | 36 |
3 | Enc1-SW | 23 | 33 |
4 | Enc2-B | 26 | 32 |
5 | Enc2-A | 21 | 29 |
6 | GND | GND | 30 |
Wire no. | Function | Pin on 2in1 |
1 | GND | - |
2 | Enc2-SW | X07 |
1.5.5.2 Controller 2
1 | Enc1-B | 04 | 16 |
2 | Enc1-A | 03 | 15 |
3 | Enc1-SW | 02 | 13 |
4 | Enc2-B | 00 | 11 |
5 | Enc2-A | 07 | 07 |
6 | GND | GND | 14 |
1 | GND | - |
2 | Enc2-SW | X08 |
PHOTO NEEDED HERE!!
1.5.7 Alternative cabling
1.6 Creating the SD
1.6.1 Getting the Image
If you successfully downloaded the whole image, you can now write it to an SD-card.
You need a minimum size of 16GB, better 32GB SDcard to allow for more instruments and sample-sets in future.
