Build a Zynthian
1 How to build a Zynthian
This manual is currently in development!
1.1 Disclaimer
1.2 Prerequisites
1.2.1 Required competences
  • Soldering
1.2.2 Tools
  • Screw drivers
  • Soldering iron
  • Tin-solder
  • Side cutter
  • Magnifiying glass
1.3 Hardware
1.3.1 Bill of Material
Notes:
  • There is no case in this BoM - You can build your own or ask Zynthian.
1.4.1 Step 1: 2in1 modules
1.4.1.1 You need:
  • 1 * 2in1 PCB (Pos. 20)
  • 1 * diode 1N4148 (pos. 1)
  • 1 * IC socket 8 pins (pos. 10) => OPTIONAL! Not included in the Kit
  • 1 * IC socket 18 pins (pos. 9) => OPTIONAL! Not included in the Kit
  • 1 * IC 6N138 (pos. 2)
  • 1 * IC MCP23008 (pos. 15)
  • 1 * 2in1 PCB (pos. 20)
1.4.1.2 HowTo:
  2. After that, solder the resistors.
  3. Then assemble the ICs.Put attention to the orientation!!. If you prefer, you can use IC sockets (but do not fit the ICs yet, we will do this at the end of this task.)
  5. If you used IC-sockets, now insert the ICs into the socket. Be careful to put them with the notch on the IC towards the hole of the white rectangle showing on the PCB!
1.4.2.2 HowTo:
  • 1 x multi-pin 4 pins angle
  • 1 x controller single PCB
1.4.3.2 HowTo:
1.4.4.1 You need:
1.4.4.2 HowTo:
1.4.5 Checking everything
Hint:
1.5 Connecting the cables
1.5.1 You need:
  • 1 * Raspberry Pi 2 (Pos. 3)
1.5.3 TFT
1.5.4 2in1
1 Vdc 3.3V 3.3V 1
2 RxD RxD 10
3 I2C SDA1 08 3
4 I2C SCL1 09 5
5 Vdc 5V 5V 2/4
6 GND GND 6/9
This step is a bit tricky. Remember that, if you follow the instructions before, you have soldered the pin-rows in the bottom side of PCBs, so numbering is reversed when looking from bottom. You can use a little trick: if you rotate the PCB 180º, then numbering is "left to right" again ;-)
PHOTO NEEDED HERE!!
1.5.5.1 Controller 1
1 Enc1-B 25 37
2 Enc1-A 27 36
3 Enc1-SW 23 33
4 Enc2-B 26 32
5 Enc2-A 21 29
6 GND GND 30
Wire no. Function Pin on 2in1
1 GND -
2 Enc2-SW X07
1.5.5.2 Controller 2
1 Enc1-B 04 16
2 Enc1-A 03 15
3 Enc1-SW 02 13
4 Enc2-B 00 11
5 Enc2-A 07 07
6 GND GND 14
1 GND -
2 Enc2-SW X08
PHOTO NEEDED HERE!!
1.5.7 Alternative cabling
1.6 Creating the SD
1.6.1 Getting the Image
Gorgona SD Image
If you successfully downloaded the whole image, you can now write it to an SD-card.
You need a minimum size of 16GB, better 32GB SDcard to allow for more instruments and sample-sets in future.
1.7 First boot
1.7.1 Testing
1.7.2 Something won't work?
