Zynthian UI User Guide - V5
Revision as of 10:58, 22 June 2024 by Riban (talk | contribs) (→‎Chains)
  • adjusting parameters
1.1 The Title Bar
1.2 The Status Area
Let's see the details:
1.2.2 The Status Icons
2.1 Chains
3 Using the push buttons
3.1 Screen access buttons
  • OPT/ADMIN
    • Admin menu
  • MIX/LEVEL
    • Mixer
  • CTRL/PRESET
    • Chain Control (Instrument)
    • Preset/Bank
  • ZS3/SNAPSHOT
    • SubSnapShots (ZS3s)
  • METRONOME
    • Tempo screen / Tap-Tempo
  • PAD/STEP
    • Scene (ZynPad)
    • Pattern
3.2 ALT button
3.3 Transport buttons
Pattern editor screen
Audio-player chain
3.4 Navigation buttons
  • Up/Down arrow buttons:
    • Browsing lists and menus.
  • Left/Right arrow buttons:
  • Select/Yes button:
  • Back/No button:
4 Using the knobs
4.1 General rule
  • Knob#1 - #4
4.3 Mixer
4.4 Scene (ZynPad)
4.5 Pattern
5 The UI Screens
6 Learning Pills
6.1 Basics
6.2 Sequencer
6.3 Mini-HowTos
7 Work In Progress
