Building a Zynthian Box using an official Kit
Zynthian Shop
2 Bill of Materials
- Zynthian Basic Kit (custom PCBs, electronic parts, wiring and knobs). Visit the Zynthian Shop
 - Case kit, with nuts, bolts and case connectors. Visit the Zynthian Shop
 - Raspberry Pi 3 (or Raspberry Pi 2)
 - HifiBerry DAC+
 - PiTFT 2.8' TouchScreen
- Resistive touchscreen (less expensive)
 - Capacitive touchscreen (better touch response)
3 Some definitions
3.1 Zynthian
3.2 Zynthian Software
What is Free Software?
3.3 Zynthian Box
3.4 Zynthian Kit
and these generic parts:
- A build with variations, by vagnscott - Another Wiring, by Imager - Success Cases
3.5 Zynthian Case
4.1 Prerequisites
4.1.1 Required Skills
4.1.2 Tools
+ Soldering iron + Tin-solder + Wire-cutter + Small Plier + Screw-drivers Philips + Wrench, for potentiometer nuts (recommended) + PCB holder for soldering (very recommended!) + Small iron brush (very recommended!) + Magnifiying glass (recommended) + A vice (recommended) + A hand saw for metal (recommended) + Multimeter (recommended!)
3. When soldering, always avoid overheating. Electronic components doesn't like overheat! This is specially important when soldering the big connectors in the HifiBerry soundcard and the PiTFT touchscreen. If you overheat the circuit, probably you will break some electronic component and you will end with a dead board. I recommend to use a fan while soldering. If not, you can use your mouth ;-) Also, don't solder the contacts in order. It's better to jump from one to another in the oposite corner. If you are not sure of your soldering skills, please, take your time and do some practice with inexpensive components and prototyping board.
6. And of course, double-check everything! Assembling and wiring process are prone to errors. Don't be too confident ;-) Re-check component's orientation (ICs and diode), wiring, etc.
+ 4 x controller PCBs + 4 x rotary encoders with switch (PEC11R-4215K-S0024) + 4 x ceramic capacitor 100nF (C1) + 8 x ceramic capacitor 10nF (c2, c3) + 4 x 4-pin-row male connector (angle)
0. Be sure that you have read and understdood these recommendations. 1. Bend the encoder's securing tabs to 75º, so you can insert it in the upside of the PCB (the labeled side!). Please, be very careful when bending the tabs as the encoder case is quite fragil and could be deformed. I recommend to use a small plier and not reaching to 90º. 2. Place the 100nF capacitor in C1 position (the most right!). This is for debouncing the push switch. 3. Place the 2 x 10nF capacitors in C2 & C3 positions. These are for debouncing the rotary encoder contacts. 3. Solder the encoder and capacitors carefully. 4. Place the pin-row connector in the downside of the PCB, with the angle pins facing inwards (look the photo!) 5. Solder the pin-row carefully. 6. Bend the pin-row outwards a little bit, like shown in the photo. You can use a screw-driver or similar to do it. 7. Use the plier to close the tabs again, trying to "catch" the PCB.
+ 1 x 2in1 PCB + 1 x GPIO-expander MCP23008 => 18-pin IC + 1 x opto-coupler 6N138 => 8-pin IC + 1 x diode 1N4148 (D1) + 1 x resistor 1K (R1) => brown-black-red (*) + 1 x resistor 10K (R2) => brown-black-orange (*) + 1 x resistor 220 (R3) => red-red-brown (*) + 2 x ceramic capacitor 100nF (C1, C2) + 1 x 8-row-pin male-angle connector + 1 x 6-row-pin male connector + 1 x 2-row-pin male connector
0. Be sure that you have read and understood these recommendations. 1. Place all the components in the upside of the PCB (the labeled side!). Put attention to the orientation of the ICs and diode. 2. Solder the components carefully. Always avoid overheating!
4.6.2 Clonic TouchScreen
Frequently, clonic PiTFT touchscreens have 4 switches welded on it. These switches can be annoying when holding the display to the case. If the switches remain pressed after mounting, then it will cause problems as they are connected to the GPIO and will conflict with the controller modules. The switches are easily pulled out by slighty turning each switch parallely to the board with a plier.
5 Case Mounting
5.3 Secure the 2in1 module
5.6 Secure the ScreenTouch
5.7 Secure the Controllers
5.8 Insert the knobs
* moisten with water or saliva the encoder stem and the knob hole * press the encoder PCB with the finger from the rear side while pushing the knob from the front side until is completely inserted
5.9 Stick the rubber feet
6 Connecting everything
6.4 Connect the 2in1 Module
6.6 Connect the ScreenTouch
7 Testing your Zynthian Box
7.2 First Boot
1. Insert the SD-card with the zynthian image ready to run. If you don't have one yet, read this. 2. Plug the mini-usb power conector. A good 5V micro-usb charger is recommended (> 1 Amp).
1. Initially, the display must go white 2. After 5-10 seconds, it will show the Zynthian splash screen 3. After 1-2 seconds, it will go black 4. If you are using a fresh zynthian image and it's the first boot, the stages 2 and 3 will be repeated 5. After 5-10 seconds, the zynthian UI will be shown
7.3 Test the Controllers
CAPTURE NEEDED HERE
or reading directly the GPIO:
# gpio readall
etc.
7.4 Test the Audio Output
7.5 Test the MIDI subsystem
7.6 Test the MIDI-USB inputs
1. Connect the audio output (RCA or Jack connector) to your amplifier or auto-amplified speakers. 2. Boot your Zynthian, select ZynAddSubFX, channel #1, bank and instrument 3. Connect a MIDI-USB keyboard to any USB port. The keyboard should be configured to use channel #1. 3. After 2-3 seconds , play something with your keyboard. A simple Chopin's Nocturni would be enough. You should hear your music ;-)
1. Connect the audio output (RCA or Jack connector) to your amplifier or auto-amplified speakers. 2. Boot your Zynthian, select ZynAddSubFX, channel #1, bank and instrument 3. Connect your keyboard's MIDI-OUT to the Zynthian's MIDI-IN using a MIDI cable. The keyboard should be configured to use channel #1. 3. After 2-3 seconds, play something with your keyboard. OK! A single melody can do the task. You should hear your song ;-)
8 Close the Case
9 Update your Zynthian Box
- connect the Zynthian Box to your router using a RJ45 cable - update zynthian software from the admin menu - update zynthian library from the admin menu - restart GUI (or reboot) from the admin menu
Display: PiTFT 2.8’ Resistive Wiring Layout: PROTOTYPE-4 Style -> Font Size: 10
More coming soon ...
11 Technical Reference
11.1 Electrical Schematic
11.2 Connection Tables
Controller Module 1
| 1 | Enc2-B | 26 | 32 |
| 2 | Enc2-A | 21 | 29 |
| 4 | GND | GND | 30 |
Controller Module 2
| 1 | Enc1-B | 25 | 37 |
| 2 | Enc1-A | 27 | 36 |
| 3 | Enc1-SW | 23 | 33 |
| 4 | GND | GND | 34 |
Controller Module 3
| 1 | Enc2-B | 00 | 11 |
| 2 | Enc2-A | 07 | 7 |
| 4 | GND | GND | 9 |
Controller Module 4
| 1 | Enc1-B | 04 | 16 |
| 2 | Enc1-A | 03 | 15 |
| 3 | Enc1-SW | 02 | 13 |
| 4 | GND | GND | 14 |
2in1 <=> RBPi
| 1 | Vdc 3.3V | 3.3V | 1 |
| 2 | RxD | RxD | 10 |
| 3 | I2C SDA1 | 08 | 3 |
| 4 | I2C SCL1 | 09 | 5 |
| 5 | Vdc 5V | 5V | 2/4 |
| 6 | GND | GND | 6/9 |
2in1 <=> MIDI-IN connector
