Assembling Zynthian Kit V5
1.1 BOM V5 kit
  • V5 Aluminum Case
    • Bottom
    • Top
  • Main Board
  • Control Board
  • Display
  • Raspberry Pi4
  • Thermal Block
  • Silicone Keypad
  • Rubber Feet (4 units)
  • Wiring
  • Screws
  • Allen Spanner 1.5 mm
  • Allen Spanner 2.0 mm
  • 27 x 20 mm
  • 11 x 11 mm
  • 11 x 9 mm
  • 6 x 6 mm
  • 27 x 20 mm
