Accessing Zynthian from your computer
Revision as of 11:40, 14 August 2026 by Fussl (talk | contribs) (Access Webconf via USB Tethering)
1 Network Connection
zynthian.local
or
zynthian.lan
Another way to connect to the Zynthian is via USB tethering. Simply connect your smartphone using a USB cable and enable USB tethering on your smartphone or tablet (refer to your device manual). The Zynthian can then use this connection to download updates or play internet radio. Important: Keep an eye on your data usage! Many mobile plans have strict limits, and large downloads can quickly use up your data allowance or incur high costs. Therefore, connect your smartphone to Wi-Fi before using USB tethering. Normally, you can access the web configuration interface (Webconf) or SSH via a web browser or SSH client using the tethering network; however, you first need to determine the Zynthian's IP address, as most devices assign a new, random IP address for each tethering session. The Zynthian's IP address is displayed on the screen under "Admin/Network Info." If the Zynthian has already established a different connection, this page will only show the IP address for that connection, not the one for the tethering connection. If the IP address cannot be determined via the display (for instance, because it is not yet configured and not working, or the Zynthian is running in "headless" mode—i.e., without a connected monitor), you may need an app on the tethering device to find the Zynthian's IP address.
An example for Android is "Ping & Net (Ping & DNS)" by Ulf Dittmer (https://www.ulfdittmer.com/view?PingNetFaq). The procedure is as follows: 1. Connect the Zynthian via USB and enable tethering. 2. Open the "Ping & Net" app. 3. Tap on "Network Info." 4. Look for "rndis0"; in the list below it, you will find an IPv6 address and an IPv4 address (the latter is the smartphone/tablet's address within the tethering network). Tap on the IPv4 address (usually starting with 10... or 192...). The main screen reappears, displaying this IP address. 5. Tap "Subnet Scan," leave the values ​​at 1 and 254, and do not select the checkbox. Confirm by tapping "OK." The IP addresses associated with the tethering network appear at the bottom of the page. 6. Tap the IP address that does not belong to your smartphone. This is the Zynthian's IP address. The main screen reappears, displaying the Zynthian's IP address. 7. Tap the "Share" icon in the top-left corner and select the device's web browser. Alternatively, you can note down the IP address and enter it manually. Repeat the process if it did not work — most likely because the wrong IP address was selected.
1.1 Wifi Configuration
1.2 Wifi Hotspot
user: root
password: opensynth
http://zynthian.local
or
http://zynthian.lan
or
Synth engines native GUI
  • 5900 (Main UI)
  • DX7 SysEX files
  • OBXd FXB files
  • synthv1 native format
  • padthv1 native format
/zynthian/zynthian-my-data
+ presets
 + zynaddsubfx
 + puredata
 + pianoteq
 + lv2
 + mod-ui
+ soundfonts
 + sf2
   + bank-1.sf2
   + bank-n.sf2
 + sfz
   + bank-1
     + sfz-bundle1
     + sfz-bundle2
   + bank-n
 + hydrogen
 + gig
   + bank-1
     + instrument-1.gig
     + instrument-n.gig
   + bank-n
+ snapshots
+ capture
/zynthian/zynthian-data
Also it's interesting:
/zynthian/config
MOD-UI pedal board style interface
http://zynthian.local:8888
or
http://zynthian.lan:8888
3 OSC (Open Sound Control)
/cuia
Example:
/cuia/restart_ui
/cuia/reboot
is interpreted the same as
/CUIA/REBOOT
import liblo
ACTION_MIDI_UNLEARN
ALL_NOTES_OFF
ALL_SOUNDS_OFF
ARROW_DOWN
ARROW_LEFT
ARROW_NEXT
ARROW_PREV
ARROW_RIGHT
ARROW_UP
AUDIO_FILE_LIST
BACK
BANK_PRESET
CLEAN_ALL
ENTER_MIDI_LEARN
EXIT_MIDI_LEARN
EXIT_UI
HIDE_BUTTONBAR
HIDE_SIDEBAR
HIDE_TOPBAR
LAST_STATE_ACTION
MENU
MIDI_UNLEARN_CHAIN
MIDI_UNLEARN_MIXER
MIDI_UNLEARN_NODE
POWER_OFF
POWER_SAVE
PRESET
PRESET_FAV
PROGRAM_CHANGE
REBOOT
RELOAD_KEY_BINDING
RELOAD_MIDI_CONFIG
RELOAD_WIRING_LAYOUT
RESTART_UI
SCREEN_ADMIN
SCREEN_ALSA_MIXER
SCREEN_ARRANGER
SCREEN_AUDIO_MIXER
SCREEN_BANK
SCREEN_CALIBRATE
SCREEN_CONTROL
SCREEN_MAIN_MENU
SCREEN_MIDI_RECORDER
SCREEN_PATTERN_EDITOR
SCREEN_PRESET
SCREEN_SNAPSHOT
SCREEN_ZS3
SCREEN_ZYNPAD
SET_TEMPO %t Set tempo BPM
SHOW_BUTTONBAR
SHOW_SCREEN
SHOW_SIDEBAR
SHOW_TOPBAR
START_AUDIO_PLAY
START_AUDIO_RECORD
START_MIDI_PLAY
START_MIDI_RECORD
STOP
STOP_AUDIO_PLAY
STOP_AUDIO_RECORD
STOP_MIDI_PLAY
STOP_MIDI_RECORD
TAP_TEMPO
TEMPO
TEMPO_DOWN
TEMPO_UP
TEST_MODE
TOGGLE_ALT_MODE
TOGGLE_AUDIO_PLAY
TOGGLE_AUDIO_RECORD
TOGGLE_MIDI_LEARN
TOGGLE_MIDI_PLAY
TOGGLE_MIDI_RECORD
TOGGLE_PLAY
TOGGLE_RECORD
TOGGLE_SCREEN
3.2 TouchOSC
/midi
import liblo
import time
cmdNoteOn = 0x90
cmdNoteOff = 0x80
note = 60
vel = 100
time.sleep(1)
