Web Configuration User Guide
1 Login
2 Dashboard
3 Library
3.1 Snapshots
3.2 Captures (Audio & MIDI)
3.3 Presets & Soundfonts
4 Hardware
4.1 Kit
4.2 Audio
4.3 Display
4.4 Wiring
4.5 Options
5 Software
5.1 Engines
5.2 Pianoteq
5.3 DSP56300
5.4 Update
5.5 Version
6 Interface
6.1 UI Options
- Save current state
- MIDI over Network
- Fonts and interface colours
6.2 UI Key Binding
6.2.1 UI Log
6.3 MIDI Options
6.3.1 Midi Profile
6.3.2 Midi fine tuning (Hz)
Make fine tuning adjustments
6.3.3 Midi Devices
Read the MIDI Filter Rule Language documentation.
6.3.5 Master Channel
6.3.6 Master Key Action
And you really can do an awful lot with a mouse! Really easy if you get a wireless(not Bluetooth) one it’s really intuitive once you learn the trick to do the back button: press or click the title bar of the screen to go back.
6.4 MIDI Log
6.5 VNC-UI
6.6 VNC-Engines
6.7 Terminal
7 System
7.1 Security / Access
7.2 Backup & Restore
8 Configuration with SSH
For Linux savvy users:
Simply edit this file:
# zynthian_update_sys.sh
