Accessing Zynthian from your computer
Revision as of 09:00, 28 June 2024 by Riban (talk | contribs) (Undo revision 13872 by Riban (talk))
1 Network Connection
1.1 Wifi Configuration
1.2 Wifi Hotspot
  1. Open the Admin screen on your Zynthian.
  4. In the Admin screen on your Zynthian, select "Network Info".
user=root
password=raspberry
http://zynthian.local or http://zynthian.lan  (or the IP address of your Zynthian)
MOD-UI pedal board style interface
Synth engines native GUI
  • 5900 (Main UI)
  • DX7 SysEX files
  • OBXd FXB files
  • synthv1 native format
  • padthv1 native format
/zynthian/zynthian-my-data
+ presets
 + zynaddsubfx
 + puredata
 + pianoteq
 + lv2
 + mod-ui
+ soundfonts
 + sf2
   + bank-1.sf2
   + bank-n.sf2
 + sfz
   + bank-1
     + sfz-bundle1
     + sfz-bundle2
   + bank-n
 + gig
   + bank-1
     + instrument-1.gig
     + instrument-n.gig
   + bank-n
+ snapshots
+ capture
/zynthian/zynthian-data
Also it's interesting:
/zynthian/config
4 OSC (Open Sound Control)
/cuia
Example:
/cuia/restart_ui
/cuia/reboot
is interpreted the same as
/CUIA/REBOOT
import liblo
ACTION_MIDI_UNLEARN
ALL_NOTES_OFF
ALL_SOUNDS_OFF
ARROW_DOWN
ARROW_LEFT
ARROW_NEXT
ARROW_PREV
ARROW_RIGHT
ARROW_UP
AUDIO_FILE_LIST
BACK
BANK_PRESET
CLEAN_ALL
ENTER_MIDI_LEARN
EXIT_MIDI_LEARN
EXIT_UI
HIDE_BUTTONBAR
HIDE_SIDEBAR
HIDE_TOPBAR
LAST_STATE_ACTION
MENU
MIDI_UNLEARN_CHAIN
MIDI_UNLEARN_MIXER
MIDI_UNLEARN_NODE
POWER_OFF
PRESET
PRESET_FAV
PROGRAM_CHANGE
REBOOT
RELOAD_KEY_BINDING
RELOAD_MIDI_CONFIG
RELOAD_WIRING_LAYOUT
RESTART_UI
SCREEN_ADMIN
SCREEN_ALSA_MIXER
SCREEN_ARRANGER
SCREEN_AUDIO_MIXER
SCREEN_BANK
SCREEN_CALIBRATE
SCREEN_CONTROL
SCREEN_MAIN_MENU
SCREEN_MIDI_RECORDER
SCREEN_PATTERN_EDITOR
SCREEN_PRESET
SCREEN_SNAPSHOT
SCREEN_ZS3
SCREEN_ZYNPAD
SET_TEMPO %t Set tempo BPM
SHOW_BUTTONBAR
SHOW_SCREEN
SHOW_SIDEBAR
SHOW_TOPBAR
START_AUDIO_PLAY
START_AUDIO_RECORD
START_MIDI_PLAY
START_MIDI_RECORD
STOP
STOP_AUDIO_PLAY
STOP_AUDIO_RECORD
STOP_MIDI_PLAY
STOP_MIDI_RECORD
TAP_TEMPO
TEMPO
TEMPO_DOWN
TEMPO_UP
TEST_MODE
TOGGLE_ALT_MODE
TOGGLE_AUDIO_PLAY
TOGGLE_AUDIO_RECORD
TOGGLE_MIDI_LEARN
TOGGLE_MIDI_PLAY
TOGGLE_MIDI_RECORD
TOGGLE_PLAY
TOGGLE_RECORD
TOGGLE_SCREEN
4.2 TouchOSC
/midi
import liblo
import time
cmdNoteOn = 0x90
cmdNoteOff = 0x80
note = 60
vel = 100
time.sleep(1)
