Zynthian UI User's Guide Appendix - Vangelis
Revision as of 17:52, 21 September 2026 by Jofemodo (talk | contribs) (→‎Quick Start)
1 Quick Start
Setup
  • Confirm operation.
  • Tap "Remove All" option.
  • Select "Insert new chain"
  • Select "Instrument"
  • Select a MIDI channel
2 Basic workflow
2.1 Chain creation
  • Access Main Menu.
2.2 Basic chain manipulation
2.3 Layering chains ("clone")
  • The easy way
  • The cool way
2.4 Etc.
3 Advanced workflow
3.1 MIDI learning
3.2 Audio routing
3.3 MIDI routing
4 Custom Control Views
4.1 Zynsampler
4.2 Sooperlooper
4.3 Tuner
4.4 Spectrum
4.5 Internet Radio
4.6 AIDA-X - High Fidelity Amp Simulator
5 CUIA: Callable UI Actions
Interface->UI Key Binding
   ‘i’ is switch 1 (top left).
   ‘o’ is switch 3 (top right).
0x9F  (Channel 16 Note ON)
0x00  (Velocity / parameter)
6 Software Version
6.1 Stable (oram-2506)
6.2 Staging (oram)
6.3 Testing (vangelis)
6.4 Custom
7 Learning Pills
7.1 Create tutorial clips with zynthian
7.2 Basics
7.3 Sequencer
7.4 Mini-HowTos
7.5 Contribute your workflow captures
Workflow log files in webconf library capture
Pressing on a specific workflow logfile brings up the mockup dialog...
Workflow Mockup in Webconf
And then you get the full brilliance of the workflow display... These run on the forum too!!
The Workflow player
