Zynthian UI User's Guide - Vangelis
1.1 How to get started
1.2 Choose your own adventure
1.3 Quick Start
Setup
  • Confirm operation.
  • Tap "Remove All" option.
  • Select "Insert new chain"
  • Select "Instrument"
  • Select a MIDI channel
1.4 The Zynthian Project
2.2 Snapshots
2.2.1 Last state snapshot
2.3 Sub-snapshots: ZS3
2.4 Signal workflow
  • Press: You can press buttons, knob-switches or display widgets. There are 3 types of press actions, depending on how long you hold down before releasing.
  • Press: You can tap display widgets. There are 3 types of tap (press) actions, depending on how long you hold down before releasing.
Ui push short icon.png Short Press Press and release in less than 0.3 seconds. Normally used to select an item, check/uncheck an option or trigger the default action for the item.
Ui push bold icon.png Bold Press Press and hold for longer than 0.3 seconds then release before 2 seconds. Normally used to open options menu, access extra details or edit the item.
Ui push long icon.png Long Press Press and hold for longer than 2 seconds. Long-action triggers before release. Used for important functions that are not used very often.
Horizontal Drag Horizontal Drag Press and drag horizontally. Must release before you can drag vertically. If still moving when released, a swipe action may occur.
Vertical Drag Vertical Drag Press and drag vertically. Must release before you can drag horizontally. If still moving when released, a swipe actin may occur.
2 Finger Horizontal Drag 2 Finger Horizontal Drag Press with 2 fingers and drag horizontally. Must release before you can drag vertically. If still moving when released, a swipe actin may occur.
2 Finger Vertical Drag 2 Finger Vertical Drag Press with 2 fingers and drag vertically. Must release before you can drag horizontally. If still moving when released, a swipe actin may occur.
Horizontal Pinch Horizontal Pinch Press with two fingers then drag horzontally towards or away from each other. Must release before you can pinch vertically.
Vertical Pinch Vertical Pinch Press with two fingers then drag vertically towards or away from each other. Must release before you can pinch horizontally.
    • short-press to select items, like the SEL button.
    • bold-press to open contextual options, like the OPT button.
    • short-press to select items.
    • short-press to go back to previous view.
  • OPT/ADMIN: long-press to power off.
  • CTRL/PRESET: long-press to enter/leave preset favorites.
  • PAD/STEP: long-press to access the arranger view.
  • short-press REC (solid circle) to start/stop a recording. When a recording is in progress, the record button lights red and you should also see the rec icon in the display status area, at top-right.
  • short-press PLAY (solid triangle) to play/pause the currently selected track. The last recorded track is selected by default. When a track is being played, the play button lights green. After pausing, pressing again will resume playing at the point it was paused.
  • bold-press PLAY to open the track list. After selecting a track, the audio player control view will be shown.
  • short-press STOP (solid square) to stop playing a track and rewind. Pressing play again will start playing from the beginning.
  • bold-press STOP to stop all sounds, including any audio/MIDI track and sequences.
    • bold-press to open the main menu.
    • long-press to open the admin menu.
    • short-press to back to the previous view.
    • bold-press to open the mixer view.
    • long-press to PANIC!. Stop all notes & sounds.
    • bold-press to open the ZS3 list.
    • long-press to open the snapshot list.
    • short-press to select/check/uncheck an item
    • bold-press to open contextual options.
    • long-press to power off the zynthian (it will ask to confirm).
Title Long press Admin menu
5 Basic workflow
5.1 Chain creation
  • Access Main Menu.
5.2 Basic chain manipulation
5.3 Layering chains ("clone")
  • The easy way
  • The cool way
5.4 Etc.
6 Advanced workflow
6.1 MIDI learning
6.2 Audio routing
6.3 MIDI routing
7 The Sequencer
7.1 Pattern Editor
    • short-press to add/remove a note at cursor position.
    • bold-press to edit note parameters:
    • short-press to restore default zoom level.
    • short-press knob#4 to end editing
    • bold-press knob#4 again to enter EDIT ALL mode
Bold-press in an empty position to edit the default note parameters. These are the values used when adding new notes.
8 Custom Control Views
8.1 Zynsampler
8.2 Sooperlooper
8.3 Tuner
8.4 Spectrum
8.5 Internet Radio
9 CUIA: Callable UI Actions
Interface->UI Key Binding
   ‘i’ is switch 1 (top left).
   ‘o’ is switch 3 (top right).
0x9F  (Channel 16 Note ON)
0x00  (Velocity / parameter)
10 Software Version
10.1 Stable (oram-2506)
10.2 Staging (oram)
10.3 Testing (vangelis)
10.4 Custom
11 Learning Pills
11.2 Basics
11.3 Sequencer
11.4 Mini-HowTos
Workflow log files in webconf library capture
Pressing on a specific workflow logfile brings up the mockup dialog...
Workflow Mockup in Webconf
