Zynthian UI User's Guide - Vangelis
1.1 How to get started
- If you would like to try Zynthian at the lowest cost, you can grab a Raspberry Pi and a few peripherals and install a basic setup (best with Pi 4b and above)
1.2 Choose your own adventure
1.3 Quick Start
Setup
- Plug audio outputs to amplification / headphones.
- Plug in audio / MIDI inputs. This may include USB MIDI devices.
- Connect power - zynthian should start up and after about 10 seconds, show the mixer view.
- Zynthian remembers its last state and there may be no chains (instruments, audio paths, etc.) shown.
- Press OPT|ADMIN button to show Chain Manager view.
- Tap touch screen "Main" box (or use arrow and SEL|YES buttons) to show the main chain options menu.
- Use arrow and SEL|YES buttons to select "Remove All".
- Confirm operation.
- Rotate encoder 4 to highlight "Main" chain.
- Bold press (press then release after 1s) encoder 4 to show Chain Manager view.
- Rotate encoder 3 to highlight "Main" box then short press (press the release within 0.5s) encoder 4 to show main chian options menu.
- Rotate encoder 4 to highlight "Remove All" then short press encoder 4 to select the menu option.
- Tap topbar (left half of black title bar at top of screen) to show Chain Manager view
- Tap touch screen "Main" box to show the main chain options menu.
- Tap "Remove All" option.
- Show the main chain options menu.
- Select "Insert new chain"
- Select "Instrument"
- Use left/right arrow buttons to select an instrument category.Use encoder 3 to select an instrument category.Swipe left/right to select an instrument category.
- Select an instrument from the list.
- Select a MIDI channel
- Select a preset bank (some instruments do not have banks so will not show this menu)
- Select a preset (some instruments do not have presets so will not show this menu)
- The "Control View" for the chain is shown.
- Play the sound from the MIDI controller connected.
1.4 The Zynthian Project
2.2 Snapshots
2.2.1 Last state snapshot
2.3 Sub-snapshots: ZS3
2.4 Signal workflow
- Press: You can press buttons, knob-switches or display widgets. There are 3 types of press actions, depending on how long you hold down before releasing.
- Press: You can tap display widgets. There are 3 types of tap (press) actions, depending on how long you hold down before releasing.
- Knob#4 is the select knob.
- short-press to select items, like the SEL button.
- bold-press to open contextual options, like the OPT button.
- layer => knob#1
- back => knob#2
- learn/shot => knob#3
- select => knob#4
- SELECT Knob
- short-press to select items.
- BACK Knob
- short-press to go back to previous view.
- Options / Menu: Opens the context menu for the current view. Press again to reach the main menu.
- OPT/ADMIN: long-press to power off.
- CTRL/PRESET: long-press to enter/leave preset favorites.
- PAD/STEP: long-press to access the arranger view.
- short-press REC (solid circle) to start/stop a recording. When a recording is in progress, the record button lights red and you should also see the rec icon in the display status area, at top-right.
- short-press PLAY (solid triangle) to play/pause the currently selected track. The last recorded track is selected by default. When a track is being played, the play button lights green. After pausing, pressing again will resume playing at the point it was paused.
- bold-press PLAY to open the track list. After selecting a track, the audio player control view will be shown.
- short-press STOP (solid square) to stop playing a track and rewind. Pressing play again will start playing from the beginning.
- bold-press STOP to stop all sounds, including any audio/MIDI track and sequences.
- UP/DOWN:
- LEFT/RIGHT:
- SEL/YES:
- BACK/NO:
- layer
- bold-press to open the main menu.
- long-press to open the admin menu.
- back
- short-press to back to the previous view.
- bold-press to open the mixer view.
- long-press to PANIC!. Stop all notes & sounds.
- learn/shot
- bold-press to open the ZS3 list.
- long-press to open the snapshot list.
- select
- short-press to select/check/uncheck an item
- bold-press to open contextual options.
- long-press to power off the zynthian (it will ask to confirm).
- S1 => MIDI Program 1
- S2 => MIDI Program 2
- S3 => MIDI Program 3
- S4 => MIDI Program 4
- S1
- long => All Sounds Off
- S2
- short => Zynpad
- bold => Pattern Editor
- S3
- short/bold => Arrow Up
- S4
- short/bold => Arrow Down
- S1
- S1 => CC 47 (value 0/127)
- S2 => CC 48 (value 0/127)
- S3 => CC 49 (value 0/127)
- S4 => CC 50 (value 0/127)
| 1st row: Health & Load | ||
5 Basic workflow
5.1 Chain creation
- Access Main Menu.
5.2 Basic chain manipulation
5.3 Layering chains ("clone")
- The easy way
- The cool way
5.4 Etc.
6 Advanced workflow
6.1 MIDI learning
6.2 Audio routing
6.3 MIDI routing
7 The Sequencer
7.1 Zynpad (Scene)
- knob#4
- short-press to play/stop the selected sequence.
- bold-press to open the pattern editor for the selected sequence.
- knob#3
- short-press to MIDI-learn the current pad by pressing a note in your MIDI controller.
- knob#2
- knob#1
Before MIDI-learning pads, you have to select a trigger device. Press OPT to access the zynpad menu and choose your trigger device. Note that if the selected device is already supported (has a driver!), MIDI-learning is not needed at all and the device will be mapped automatically.
7.2 Pattern Editor
- short-press to add/remove a note at cursor position.
- bold-press to edit note parameters:
- short-press to restore default zoom level.
- short-press knob#4 to end editing
- bold-press knob#4 again to enter EDIT ALL mode
Bold-press in an empty position to edit the default note parameters. These are the values used when adding new notes.
8 Custom Control Views
8.1 Zynsampler
8.2 Sooperlooper
- REC
- F4 adds a new empty loop
8.3 Tuner
8.4 Spectrum
8.5 Internet Radio
9 CUIA: Callable UI Actions
Interface->UI Key Binding
10 Software Version
10.1 Stable (oram-2506)
10.2 Staging (oram)
10.3 Testing (vangelis)
10.4 Custom
11 Learning Pills
11.2 Basics
11.3 Sequencer
11.4 Mini-HowTos
