Zynthian UI User's Guide - Vangelis
1.1 How to get started
- If you would like to try Zynthian at the lowest cost, you can grab a Raspberry Pi and a few peripherals and install a basic setup (best with Pi 4b and above)
1.2 Choose your own adventure
1.3 Quick Start
Setup
- Plug audio outputs to amplification / headphones.
- Plug in audio / MIDI inputs. This may include USB MIDI devices.
- Connect power - zynthian should start up and after about 10 seconds, show the mixer view.
- Zynthian remembers its last state and there may be no chains (instruments, audio paths, etc.) shown.
- Press OPT|ADMIN button to show Chain Manager view.
- Tap touch screen "Main" box (or use arrow and SEL|YES buttons) to show the main chain options menu.
- Use arrow and SEL|YES buttons to select "Remove All".
- Confirm operation.
- Rotate encoder 4 to highlight "Main" chain.
- Bold press (press then release after 1s) encoder 4 to show Chain Manager view.
- Rotate encoder 3 to highlight "Main" box then short press (press the release within 0.5s) encoder 4 to show main chian options menu.
- Rotate encoder 4 to highlight "Remove All" then short press encoder 4 to select the menu option.
- Tap topbar (left half of black title bar at top of screen) to show Chain Manager view
- Tap touch screen "Main" box to show the main chain options menu.
- Tap "Remove All" option.
- Show the main chain options menu.
- Select "Insert new chain"
- Select "Instrument"
- Use left/right arrow buttons to select an instrument category.Use encoder 3 to select an instrument category.Swipe left/right to select an instrument category.
- Select an instrument from the list.
- Select a MIDI channel
- Select a preset bank (some instruments do not have banks so will not show this menu)
- Select a preset (some instruments do not have presets so will not show this menu)
- The "Control View" for the chain is shown.
- Play the sound from the MIDI controller connected.
1.4 The Zynthian Project
Chains receive MIDI data from a set of MIDI inputs. These MIDI inputs could be external MIDI devices connected to MIDI DIN-5 or USB MIDI (sequencers, keyboards and other MIDI controllers) or other MIDI sources (MIDI network services, internal sources like the built-in sequencer, etc.) and they can be configured for each chain separately. Each MIDI input can work in 2 different modes:
- Press: You can press buttons, knob-switches or display widgets. There are 3 types of press actions, depending on how long you hold down before releasing.
- Press: You can tap display widgets. There are 3 types of tap (press) actions, depending on how long you hold down before releasing.
- Knob#4 is the select knob.
- short-press to select items, like the SEL button.
- bold-press to open contextual options, like the OPT button.
- layer => knob#1
- back => knob#2
- learn/shot => knob#3
- select => knob#4
- SELECT Knob
- short-press to select items.
- BACK Knob
- short-press to go back to previous view.
- Options / Menu: Opens the context menu for the current view. Press again to reach the main menu.
- OPT/ADMIN: long-press to power off.
- CTRL/PRESET: long-press to enter/leave preset favorites.
- PAD/STEP: long-press to access the arranger view.
- short-press REC (solid circle) to start/stop a recording. When a recording is in progress, the record button lights red and you should also see the rec icon in the display status area, at top-right.
- short-press PLAY (solid triangle) to play/pause the currently selected track. The last recorded track is selected by default. When a track is being played, the play button lights green. After pausing, pressing again will resume playing at the point it was paused.
- bold-press PLAY to open the track list. After selecting a track, the audio player control view will be shown.
- short-press STOP (solid square) to stop playing a track and rewind. Pressing play again will start playing from the beginning.
- bold-press STOP to stop all sounds, including any audio/MIDI track and sequences.
- UP/DOWN:
- LEFT/RIGHT:
- SEL/YES:
- BACK/NO:
- layer
- bold-press to open the main menu.
- long-press to open the admin menu.
- back
- short-press to back to the previous view.
- bold-press to open the mixer view.
- long-press to PANIC!. Stop all notes & sounds.
- learn/shot
- bold-press to open the ZS3 list.
- long-press to open the snapshot list.
- select
- short-press to select/check/uncheck an item
- bold-press to open contextual options.
- long-press to power off the zynthian (it will ask to confirm).
- S1 => MIDI Program 1
- S2 => MIDI Program 2
- S3 => MIDI Program 3
- S4 => MIDI Program 4
- S1
- long => All Sounds Off
- S2
- short => Zynpad
- bold => Pattern Editor
- S3
- short/bold => Arrow Up
- S4
- short/bold => Arrow Down
- S1
- S1 => CC 47 (value 0/127)
- S2 => CC 48 (value 0/127)
- S3 => CC 49 (value 0/127)
- S4 => CC 50 (value 0/127)
| 1st row: Health & Load | ||
- solo: Solo flag. Press to toggle. This is a non-exclusive solo mode. When a chain has solo enabled, all other chains without solo enabled will be muted, allowing auditioning of one or more chains. The main solo will disable all chain solos.
- mute: Mute flag. Press to toggle. When a chain is muted (it has "mute" enabled), it will remain silent.
- knob#1
- short-press to solo the active chain.
- knob#2
- short-press to mute the active chain.
- knob#3
- short-press to add a chain.
- knob#4
- short-press to open the chain control view for the active chain.
- bold-press to open the chain options for the active chain.
- SEL
- layer
- back
- bold-press to toggle mixer view and launcher view
- learn/shot
- select
- bold-press to open the chain manager view.
- create a new chain
- remove an existing chain
- remove all chains
- remove all sequences
- remove all
- Sequencer
- Tempo Settings
- Mixer Learn
- knob#4
- short-press or bold-press to select the highlighted option.
- back
- short-press to close the menu and return to previous view.
- select
- short-press or bold-press to select an option.
- Description (text): A concise description of the processor's features. Press it to open the detailed info view.
- knob#3
- short-press to open the full info view.
- knob#4
- short-press to select a processor.
- bold-press to toggle view-all mode.
- SEL to select a processor.
- knob#3
- knob#4
- short-press to enable/disable processors.
- bold-press to back to normal mode.
- back
- short-press to cancel selection and return to previous view.
- learn/shot
- select
- short-press or to select the highlighted processor.
- bold-press or to toggle view all mode.
- back
- short-press to back to normal mode.
- learn/shot
- select
- short-press or to enable/disable processor.
- bold-press or to back to normal mode.
Chain MIDI learning:
Global MIDI learning:
- knob#1 - knob#4
- short-press any knob to start MIDI-learning for the associated parameter. First press for chain MIDI-learn, second press for global MIDI-learn.
- bold-press any knob to open the options menu for the associated parameter.
- knob#4
- short-press to select page and back to control mode
- knob#1 - knob#4
- from the control view, short-press any knob for entering chain MIDI-learning mode. The controller widget will display a green ?? legend.
- a second short-press for global MIDI-learning. The controller widget will display a yellow ??#?? legend.
- a third press to cancel MIDI-learning.
- layer
- short-press to rotate active chain.
- back
- short-press to open the preset list for the selected processor.
- learn/shot
- short-press any knob to start MIDI-learning.
- select
- short-press to enter select mode.
- bold-press to open the chain options view.
- back
- short-press to exit from select mode.
- select
- short-press to select page and back to control mode.
- back
- short-press to cancel midi learning.
- learn/shot
- from the control view, short-press for entering chain MIDI-learning mode. Controller widgets will display a green ?? legend.
- a second short-press for global MIDI-learning. Controller widgets will display a yellow ??#?? legend.
- a third short-press to cancel MIDI-learning.
In addition, the preset options can be accessed by bold-pressing any preset. The available options depends of the processor and whether the preset is a user or system preset.
- knob#4
- short-press to select the highlighted preset.
- bold press to open the preset options.
- SEL
- knob#4
- short-press or bold-press to select/check option.
- SEL to select/check option.
- back
- short-press to open bank selection view or back to control view.
- select
- short-press to select a preset.
- bold-press to open the the preset options.
- back
- short-press to close preset options and back to presets list.
- select
- short-press or bold-press to select/check an option.
In addition, the bank options can be accessed by bold-pressing any bank. The available options depends of the processor and whether the bank is a user or system bank.
- knob#4
- short-press to select the highlighted bank.
- bold press to open the bank options.
- SEL
- back
- short-press to close the bank selection and return to control view.
- select
- short-press to select a bank.
- bold-press to open the bank options.
- replace the processor
- remove the processor
- knob#3
- knob#4
- short-press or bold-press to select an option or open the processor options.
- knob#4
- SEL
- back
- short-press to return to previous view.
- learn/shot
- select
- back
- short-press back to previous view.
- select
- bluetooth MIDI devices
- MIDI network services
Bold press on any device to access the device options:
- rename the device
The Chain's MIDI input/output view is accessed from the chain's options menu. It allows you to select the devices from which it will receive MIDI input or to which it will send MIDI output. You can also access the device options by bold-pressing any device.
- knob#4
- short-press to check/uncheck a device.
- bold press to open the device options.
- SEL
- knob#4
- short-press or bold-press to check/uncheck an option.
- SEL
- back
- short-press to close the view and back to chain options.
- select
- bold-press to open the device options.
- back
- select
- short-press back button to close the view and back to chain options.
- short-press on list item to check/uncheck a device or enable/disable network/bluetooth service
- bold-press on a MIDI device to open the device options.
5.12 MIDI Learn
5.13 Audio Out
5.14 Mixer Options
5.15 Processor Options
5.16 Snapshots
5.17 ZS3 (sub-snapshots)
5.18 Confirmation dialog
5.19 On-screen keyboard
5.20 Admin
- the MIDI ins and outs menus
- touchscreen calibration
- power & reboot
5.22 Audio levels
- Access Main Menu.
- The easy way
- The cool way
- knob#4
- short-press to play/stop the selected sequence.
- bold-press to open the pattern editor for the selected sequence.
- knob#3
- short-press to MIDI-learn the current pad by pressing a note in your MIDI controller.
- knob#2
- knob#1
Before MIDI-learning pads, you have to select a trigger device. Press OPT to access the zynpad menu and choose your trigger device. Note that if the selected device is already supported (has a driver!), MIDI-learning is not needed at all and the device will be mapped automatically.
- short-press to add/remove a note at cursor position.
- bold-press to edit note parameters:
- short-press to restore default zoom level.
- short-press knob#4 to end editing
- bold-press knob#4 again to enter EDIT ALL mode
Bold-press in an empty position to edit the default note parameters. These are the values used when adding new notes.
- Tempo adjustment (BPM)
- Metronome toggle and
- Metronome volume
- Audio record/playback and
- Midi record/playback
| Clock Source Options | |
- REC
- F4 adds a new empty loop
10 CUIA: Callable UI Actions
Interface->UI Key Binding
11 Software Version
11.1 Stable (oram-2506)
11.2 Staging (oram)
11.3 Testing (vangelis)
11.4 Custom
12 Learning Pills
12.2 Basics
12.3 Sequencer
12.4 Mini-HowTos
