Zynthian UI User's Guide - Vangelis
1.1 How to get started
1.2 Choose your own adventure
This user guide describes how to start with zynthian but does not delve into much detail. There is built-in help within the zynthian that provides contextural help. Access this at any time by
BOLD PRESS ALT
LONG PRESS Knob 1
You can select the documentation for different hardware types (V5 or V4) with the selector in the top right of the page
1.3 Quick Start
Setup
  • Press OPT|ADMIN button to show Chain Manager view.
  • Tap touch screen "Main" box (or use arrow and SEL|YES buttons) to show the main chain options menu.
  • Use arrow and SEL|YES buttons to select "Remove All".
  • Confirm operation.
  • Tap "Remove All" option.
  • Select "Insert new chain"
  • Select "Instrument"
  • Select a MIDI channel
1.4 The Zynthian Project
Chains receive MIDI data from a set of MIDI inputs. These MIDI inputs could be external MIDI devices connected to MIDI DIN-5 or USB MIDI (sequencers, keyboards and other MIDI controllers) or other MIDI sources (MIDI network services, internal sources like the built-in sequencer, etc.) and they can be configured for each chain separately. Each MIDI input can work in 2 different modes:
Title Long press Admin menu
  • solo: Solo flag. Push to toggle. This is a non-exclusive solo mode. When a chain has solo enabled, all other chains without solo enabled will be muted, allowing auditioning of one or more chains. The main solo will disable all chain solos.
    • short-push to add a chain.
    • bold-push to toggle mixer view and launcher view
    • bold-push to open the chain manager view.
Chain Legend Bold press Show chain manager view
Chain MIDI learning:
Global MIDI learning:
  • bluetooth MIDI devices
  • MIDI network services
5.12 MIDI Learn
5.13 Audio Out
5.14 Mixer Options
5.15 Processor Options
5.16 Snapshots
5.17 ZS3 (sub-snapshots)
5.18 Confirmation dialog
5.19 On-screen keyboard
5.20 Admin
  • the MIDI ins and outs menus
  • touchscreen calibration
  • power & reboot
5.22 Audio levels
  • Access Main Menu.
  • The easy way
  • The cool way
Arranger View
  • Tempo adjustment (BPM)
  • Metronome toggle and
  • Metronome volume
  • Audio record/playback and
  • Midi record/playback
Clock Source Options
10 CUIA: Callable UI Actions
Interface->UI Key Binding
   ‘i’ is switch 1 (top left).
   ‘o’ is switch 3 (top right).
0x9F  (Channel 16 Note ON)
0x00  (Velocity / parameter)
11 Software Version
11.1 Stable (oram-2506)
11.2 Staging (oram)
11.3 Testing (vangelis)
11.4 Custom
12 Learning Pills
12.2 Basics
12.3 Sequencer
12.4 Mini-HowTos
