Zynthian UI User's Guide - Vangelis
The hardware includes the various official boxes from v1 through to the current (as of March 2026) V5.1 (see how some early versions evolved). On the software side, Zynthian Oram is the most recent version of zynthianOS, first released in September 2024 but this guide is for the development version that is prone to unannounced changes.
1.1 How to get started
- If you would like to try Zynthian at the lowest cost, you can grab a Raspberry Pi and a few peripherals and install a basic setup (best with Pi 4b and above)
1.2 Choose your own adventure
This user guide describes how to start with zynthian but does not delve into much detail. There is built-in help within the zynthian that provides contextural help. Access this at any time by
1.3 Quick Start
Setup
- Plug audio outputs to amplification / headphones.
- Plug in audio / MIDI inputs. This may include USB MIDI devices.
- Connect power - zynthian should start up and after about 10 seconds, show the mixer view.
- Zynthian remembers its last state and there may be no chains (instruments, audio paths, etc.) shown.
- Press OPT|ADMIN button to show Chain Manager view.
- Tap touch screen "Main" box (or use arrow and SEL|YES buttons) to show the main chain options menu.
- Use arrow and SEL|YES buttons to select "Remove All".
- Confirm operation.
- Rotate encoder 4 to highlight "Main" chain.
- Bold press (press then release after 1s) encoder 4 to show Chain Manager view.
- Rotate encoder 3 to highlight "Main" box then short press (press the release within 0.5s) encoder 4 to show main chian options menu.
- Rotate encoder 4 to highlight "Remove All" then short press encoder 4 to select the menu option.
- Tap topbar (left half of black title bar at top of screen) to show Chain Manager view
- Tap touch screen "Main" box to show the main chain options menu.
- Tap "Remove All" option.
- Show the main chain options menu.
- Select "Insert new chain"
- Select "Instrument"
- Use left/right arrow buttons to select an instrument category.Use encoder 3 to select an instrument category.Swipe left/right to select an instrument category.
- Select an instrument from the list.
- Select a MIDI channel
- Select a preset bank (some instruments do not have banks so will not show this menu)
- Select a preset (some instruments do not have presets so will not show this menu)
- The "Control View" for the chain is shown.
- Play the sound from the MIDI controller connected.
1.4 The Zynthian Project
Chains receive MIDI data from a set of MIDI inputs. These MIDI inputs could be external MIDI devices connected to MIDI DIN-5 or USB MIDI (sequencers, keyboards and other MIDI controllers) or other MIDI sources (MIDI network services, internal sources like the built-in sequencer, etc.) and they can be configured for each chain separately. Each MIDI input can work in 2 different modes:
- Knob#4 is the select knob.
- layer => knob#1
- back => knob#2
- learn/shot => knob#3
- select => knob#4
- SELECT Knob
- short-push to select items.
- BACK Knob
- UP/DOWN:
- LEFT/RIGHT:
- SEL/YES:
- BACK/NO:
- layer
- back
- learn/shot
- select
- S1 => MIDI Program 1
- S2 => MIDI Program 2
- S3 => MIDI Program 3
- S4 => MIDI Program 4
- S1
- long => All Sounds Off
- S2
- short => Zynpad
- bold => Pattern Editor
- S3
- short/bold => Arrow Up
- S4
- short/bold => Arrow Down
- S1
- S1 => CC 47 (value 0/127)
- S2 => CC 48 (value 0/127)
- S3 => CC 49 (value 0/127)
- S4 => CC 50 (value 0/127)
| 1st row: Health & Load | ||
- solo: Solo flag. Push to toggle. This is a non-exclusive solo mode. When a chain has solo enabled, all other chains without solo enabled will be muted, allowing auditioning of one or more chains. The main solo will disable all chain solos.
- knob#1
- knob#2
- knob#3
- short-push to add a chain.
- knob#4
- SEL
- layer
- back
- bold-push to toggle mixer view and launcher view
- learn/shot
- select
- bold-push to open the chain manager view.
- create a new chain
- remove an existing chain
- remove all chains
- remove all sequences
- remove all
- Sequencer
- Tempo Settings
- Mixer Learn
- knob#4
- back
- select
- knob#3
- knob#4
- SEL to select a processor.
- knob#3
- knob#4
- back
- learn/shot
- select
- back
- learn/shot
- select
Chain MIDI learning:
Global MIDI learning:
- knob#1 - knob#4
- knob#4
- knob#1 - knob#4
- layer
- back
- learn/shot
- select
- back
- select
- back
- learn/shot
- knob#4
- SEL
- knob#4
- SEL to select/check option.
- back
- select
- back
- select
- knob#4
- SEL
- back
- select
- replace the processor
- remove the processor
- knob#3
- knob#4
- knob#4
- SEL
- back
- learn/shot
- select
- back
- select
- bluetooth MIDI devices
- MIDI network services
- rename the device
- knob#4
- SEL
- knob#4
- SEL
- back
- select
- back
- select
5.12 MIDI Learn
5.13 Audio Out
5.14 Mixer Options
5.15 Processor Options
5.16 Snapshots
5.17 ZS3 (sub-snapshots)
5.18 Confirmation dialog
5.19 On-screen keyboard
5.20 Admin
- the MIDI ins and outs menus
- touchscreen calibration
- power & reboot
5.22 Audio levels
- Access Main Menu.
- The easy way
- The cool way
- knob#4
- knob#3
- knob#2
- knob#1
- Tempo adjustment (BPM)
- Metronome toggle and
- Metronome volume
- Audio record/playback and
- Midi record/playback
| Clock Source Options | |
- REC
- F4 adds a new empty loop
10 CUIA: Callable UI Actions
Interface->UI Key Binding
11 Software Version
11.1 Stable (oram-2506)
11.2 Staging (oram)
11.3 Testing (vangelis)
11.4 Custom
12 Learning Pills
12.2 Basics
12.3 Sequencer
12.4 Mini-HowTos
