Zynthian UI User's Guide - Vangelis
Revision as of 08:08, 6 March 2026 by Riban (talk | contribs) (Undo revision 15933 by Riban (talk))
The hardware includes the various official boxes from v1 through to the current (as of March 2026) V5.1 (see how some early versions evolved). On the software side, Zynthian Oram is the most recent version of zynthianOS, first released in September 2024 but this guide is for the development version that is prone to unannounced changes.
1.1 How to get started
1.2 Choose your own adventure
1.3 Quick Start
Setup
  • Press OPT|ADMIN button to show Chain Manager view.
  • Tap touch screen "Main" box (or use arrow and SEL|YES buttons) to show the main chain options menu.
  • Use arrow and SEL|YES buttons to select "Remove All".
  • Confirm operation.
  • Tap "Remove All" option.
  • Select "Insert new chain"
  • Select "Instrument"
  • Select a MIDI channel
1.4 The Zynthian Project
Chains receive MIDI data from a set of MIDI inputs. These MIDI inputs could be external MIDI devices connected to MIDI DIN-5 or USB MIDI (sequencers, keyboards and other MIDI controllers) or other MIDI sources (MIDI network services, internal sources like the built-in sequencer, etc.) and they can be configured for each chain separately. Each MIDI input can work in 2 different modes:
Zynaudio8X uses an ALSA driver written by me for a project described else where in the forum for up to 4 x stereo I2S DACs. IIRC it may also support up to 4 x stereo ADCs. Selecting it in webconf HARDWARE->Audio, Soundcard drop-down list will populate Driver Config: ``` dtoverlay=zynaudio8x,inputs=8,outputs=8 ``` You can change this to have fewer inputs and outputs, e.g. ``` dtoverlay=zynaudio8x,inputs=0,outputs=4 ```
2.3.1 Last state snapshot
2.4 Sub-snapshots: ZS3
Title Short press Show menu
Title Bold press ZynPad view
Title Long press Admin menu
Chain MIDI learning:
Global MIDI learning:
  • bluetooth MIDI devices
  • MIDI network services
5.12 MIDI Learn
5.13 Audio Out
5.14 Mixer Options
5.15 Processor Options
5.16 Snapshots
5.17 ZS3 (sub-snapshots)
5.18 Confirmation dialog
5.19 On-screen keyboard
5.20 Admin
  • the MIDI ins and outs menus
  • touchscreen calibration
  • power & reboot
5.22 Audio levels
  • Access Main Menu.
  • The easy way
  • The cool way
Arranger View
  • Tempo adjustment (BPM)
  • Metronome toggle and
  • Metronome volume
  • Audio record/playback and
  • Midi record/playback
Clock Source Options
10 CUIA: Callable UI Actions
Interface->UI Key Binding
   ‘i’ is switch 1 (top left).
   ‘o’ is switch 3 (top right).
0x9F  (Channel 16 Note ON)
0x00  (Velocity / parameter)
11 Software Version
11.1 Stable (oram-2506)
11.2 Staging (oram)
11.3 Testing (vangelis)
11.4 Custom
12 Learning Pills
12.2 Basics
12.3 Sequencer
12.4 Mini-HowTos
