Refactoring Zynthians factory soundfont library
1.2.1.1 Pro own repository
1.2.1.2 Pro pulling upstream
- CC-0: OK. You can do whatever you like with these samples. Because we value intellectual property very much, we'll credit creators and sources anyway. And of course we keep the license file.
- CC-BY: OK. We need to credit the author, which we want to do anyway.
- CC-BY-SA: OK. In my understanding, given ZynthianOS is licensed under GPL-3, the BY-SA is one way compatible to this. So when we credit the author, we're fine.
- CC-BY-NC-SA: OK. In my understanding, the ZynthianOS licensed under GPL-3 independently from the commercial kit being sold, is a non-commercial undertake.
- CC-BY-ND: CRITICAL. We might use this library in unchanged form, which prohibits zynthian specific editing.
- CC BY-NC-ND: CRITICAL. Same as above.
1.4.1 Curating vs. collecting
1.5.2 Level matching?
We would need a standard, and perhaps two: one for polyphonic and one for monophonic instruments. For example, we could have two MIDI files (mono vs poly) where each plays a series of notes or chords, and state a goal in terms of LUFS for the resulting audio. This is scriptable (with a number of dependencies, like sfizz-render and soz.) I (Jeff Learman) will look into this. Note that this only works for sfz samplesets, but IMHO that's what we should be targeting, using sfizz.
2 Practice
2.1 Roadmap
- Make decisions concerning the key desing decisions above
- Initiating a publically available github repository based in the existing patches OR create a new blank one only containing folders for categories and edit away
- Drafting the distribution process (including in download image, github pull, webconf package?). Immediate distribution vs. distribution on finishing the project.
- Writing guidelines containing infos on license files, READMEs, target size, target engine, general and category specific common controls and editing notes
- Choosing candidates for including, preferably with CC-0 license
- Editing
- Complying with given license is mandatory. Missing license files are being added from original sources, otherwise soundfont must be dropped. This doesn't apply for missing licenses of the sfz script if that script is obviously trivial (list of regions connecting files with note values). Each Instrument contains a license file regarding samples and scripts and at least a zynthian specific README which can be displayed in the patch selection window. CC-BY-ND licences samples are included by git submodule if it is usable in the recommended soundfont player (i.e. Sfizz)
- Sampleset is usable out of the box by preferred engine (i.e. Sfizz) omiting or replacing opcodes these engines cannot use
- Issues are being fixed
- [Target maximum size and how to achieve it]
- [Limit the number of patches per instrument type?]
- [Unifying multiple files (e.g. articulations) into one]
- [Common folder structure]
- Instrument contains a *.yml file. But for simpler sfz the autogeneration might be sufficient.
- [Common controls]
- [Instrument specific controls]
- [Level matching]
Please note that the purpose of this list is:
- to collect ideas and as an inspiration for identifying good samplesets of either category
- to be enhanced, filled and changed by all members
- not to limit the number of samplesets per instrument type, just add rows as needed.
For "P/W" category, "P" is for "pre-loaded"; "W" is for webconf packages.
Licenses:
- PD - public domain but not explicitly licensed at the source, for secondary only.
- Q - questionable or completely undocumented
- CC license short name
- GNU GPL & variants
- Unlicense - specifically using Github or similar Unlicense option, equivalent to CC0
| Instrument | source | license | editor | size | P/W | notes |
| Acoustic Pianos | ||||||
| 01 Grand Piano | Accurate Salamander Grand v6.2beta2 | CC BY | jlearman | 200M | P | Lovingly reprocessed Salamander Grand with more even dynamics, and with latency issues fixed. See https://github.com/jlearman/zynthian-salamander-grand for zynthian-ized version. |
| " | Splendid Grand | PD | jlearman | 136M | P | - |
| 02 Upright Piano | - | - | - | - | - | |
| 03 Felt Piano | Karoryfer Oasis Piano | CC-BY | jlearman | ? | W | not yet available but coming soon. Currently 4G but easily reduced. |
| 04 Honkytonk | - | - | - | - | - | |
| 05 Harpsichord | - | - | - | - | - | |
| Electric Pianos | ||||||
| 01 EP Rhodes | jRhodes3c | CC BY-NC-SA | jlearman | P | "aka Stereo Rhodes." Looped samples. I plan to relax the license to CC BY-SA | |
| " | jRhodes3d | CC BY-NC | jlearman | W | Unlooped stereo rhodes. I plan some updates. | |
| " | current Rhodes sampleset | TBD | jlearman | P | - | |
| 02 EP Wurlitzer | - | - | - | - | - | |
| 03 EP Hohner Pianet T | - | - | - | - | - | |
| 04 EP Clavinet | - | - | - | - | - | |
| 05 EP CP70 | - | - | - | - | - | |
| 06 Synth Keys | - | - | - | - | - | |
| 07 Sampled Keys | - | - | - | - | - | |
| Chromatic Percussion | ||||||
| 01 Celeste | - | - | - | - | - | |
| 02 Vibraphone | VCSL Vibraphone | CC-0 | ? | ? | Three articulations (bowed, hard and soft mallet), two velocity layers, sounds great | |
| 03 Marimba | VCSL Marimba | CC-0 | ? | ? | Two velocity layers | |
| " | Terkelsen Marimba | Q | jlearman | - | ||
| 04 Xylophone | VCSL Xylophone | CC-0 | ? | ? | Three articulations (hard, med, soft mallet), two velocity layers | |
| 05 Glockenspiel | VCSL Glockenspiel | CC-0 | ? | ? | Three velocity layers | |
| 06 Steel Drums | jSteelDrum | Unlicense | jlearman | P | - | |
| 07 Kalimba | VCSL Kalimba, Kenya | CC-0 | ? | ? | Two round robins, there is another Kalimba in the same folder in the repo | |
| 08 Music Box | - | - | - | - | - | |
| 10 Dulcimer | - | - | - | - | - | |
| 11 Koto | - | - | - | - | - | |
| 12 Tubular Bell | - | - | - | - | - | |
| 13 Church/Charillon Bell | - | - | - | - | - | |
| 14 Timpani | VSCO Timpani | CC-0 | ? | ? | 4 Vel-layers, 2 RR | |
| Organs & Reed | ||||||
| 01 Drawbar Organ | - | - | - | - | - | |
| 02 Pipe/Church Organ | - | - | - | - | - | |
| 03 Reed Organ | - | - | - | - | - | |
| 04 Harmonium | - | - | - | - | - | |
| 05 Accordion | - | - | - | - | - | |
| 06 Harmonica | VCSL Hohner F20 | CC-0 | ? | ? | Multiple articulations | |
| 07 Melodica | - | - | - | - | - | |
| 08 Bagpipes | - | - | - | - | - | |
| 09 Duduk | - | - | - | - | - | |
| Synth (might be abandoned in favor for the synth engines) | ||||||
| 01 Lead | - | - | - | - | - | |
| 02 Pad | - | - | - | - | - | |
| 03 FM/Keys | - | - | - | - | - | |
| 04 Bass | - | - | - | - | - | |
| 05 String | - | - | - | - | - | |
| 06 Brass | - | - | - | - | - | |
| 07 Organ | - | - | - | - | - | |
| 08 Arp | - | - | - | - | - | |
| 09 Modular | - | - | - | - | - | |
| 10 Theremin | - | - | - | - | - | |
| Guitar | ||||||
| 01 Acoustic Guitar | - | - | - | - | - | |
| 02 Electric Guitar (Clean) | - | - | - | - | - | |
| 03 Electric Guitar (Distorted) | - | - | - | - | - | |
| 04 Jazz Guitar | - | - | - | - | - | |
| Guitarophone | ||||||
| 01 Mandolin | - | - | - | - | - | |
| 02 Ukulele | - | - | - | - | - | |
| 03 Banjo | - | - | - | - | - | |
| 04 Oud | - | - | - | - | - | |
| 05 Lute | - | - | - | - | - | |
| 06 Sitar | - | - | - | - | - | |
| 07 Harp | - | - | - | - | - | |
| 08 Zither | - | - | - | - | - | |
| 09 Shamisen | - | - | - | - | - | |
| Bass | ||||||
| 01 Upright Bass | Karoryfer Meatbass | CC-0 | ? | ? | Deeply sampled and rounder in sound than the Rubner bass (which is also great) | |
| 02 Acoustic Bass | - | - | - | - | - | |
| 03 Electric Bass | Karoryfer Black and Blue | CC-0 | ? | ? | Deeply sampled | |
| Strings (The majority of the next five sections can be filled with Versilian's VSCO) | ||||||
| 01 Violin | - | - | - | - | - | |
| 02 Viola | - | - | - | - | - | |
| 03 Cello | - | - | - | - | - | |
| 04 Double Bass | - | - | - | - | - | |
| 05 Solo Ensemble | - | - | - | - | - | |
| 06 Chamber Ensemble | - | - | - | - | - | |
| 07 Orchestral Ensemble | - | - | - | - | - | |
| 08 Fiddle | - | - | - | - | - | |
| Brass | ||||||
| 02 Flugelhorn | - | - | - | - | - | |
| 03 French Horn | - | - | - | - | - | |
| 04 Trumpet | - | - | - | - | - | |
| 05 Trombone | - | - | - | - | - | |
| 06 Tuba | - | - | - | - | - | |
| 07 Cimbasso | - | - | - | - | - | |
| 08 Solo Ensemble | - | - | - | - | - | |
| 09 Chamber Ensemble | - | - | - | - | - | |
| 10 Orchestral Ensemble | - | - | - | - | - | |
| 11 Soul Brass Trio | - | - | jlearman | |||
| Woodwinds | ||||||
| 01 Flute | - | - | - | - | - | |
| 02 Oboe | - | - | - | - | - | |
| 03 Bassoon | - | - | - | - | - | |
| 04 English Horn | - | - | - | - | - | |
| 05 Recorder | Versilian Recorder CE | CC-BY | ? | ? | Has soprano, alto, tenor, bass, greatbass, and contrabass recorder | |
| 06 Pan Flute | - | - | - | - | - | |
| 07 Tin Whistle | - | - | - | - | - | |
| Reeds | ||||||
| 01 Soprano Saxophone | - | - | - | - | - | |
| 02 Alto Saxophone | - | - | - | - | - | |
| 03 Tenor Saxophone | Karoryfer Weresax | CC-0 | ? | ? | - | |
| 04 Baritone Saxophone | Karoryfer Bearsax | CC-0 | ? | ? | - | |
| 05 Clarinet | - | - | - | - | - | |
| 06 Bass Clarinet | - | - | - | - | - | |
| 07 Solo Ensemble | - | - | - | - | - | |
| 08 Chamber Ensemble | - | - | - | - | - | |
| 09 Orchestral Ensemble | - | - | - | - | - | |
| Choirs | ||||||
| 01 Solo Voice | - | - | - | - | - | |
| 02 Choir | - | - | - | - | - | |
| Acoustic Drums | ||||||
| 01 Rock | - | - | - | - | - | |
| 02 Jazz | Versilian Virtuosity Drums | CC-0 | ? | ? | Really great but also really huge. We could make a custom reduced set | |
| 03 Brush | - | - | - | - | - | |
| 04 Mallet | - | - | - | - | - | |
| Electronic Drums | ||||||
| 01 808 | - | - | - | - | - | |
| 02 909 | - | - | - | - | - | |
| 03 606 | - | - | - | - | - | |
| 04 LinnDrum | - | - | - | - | - | |
| 05 … | - | - | - | - | - | |
| Percussion | ||||||
| 01 Hand Percussion | - | - | - | - | - | |
| 02 Orchestral Percussion | - | - | - | - | - | |
| Miscellanious | ||||||
| 01 Found Sounds | - | - | - | - | - | |
| 02 Field Recordings | - | - | - | - | - | |
| 03 FX | - | - | - | - | - | |
