Refactoring Zynthians factory soundfont library
Revision as of 16:18, 14 June 2026 by Jlearman (talk | contribs) (→‎Candidates: List of top contenders per category: update to accurate salamander grand)
1.2.1.1 Pro own repository
1.2.1.2 Pro pulling upstream
1.4.1 Curating vs. collecting
1.5.2 Level matching?
We would need a standard, and perhaps two: one for polyphonic and one for monophonic instruments. For example, we could have two MIDI files (mono vs poly) where each plays a series of notes or chords, and state a goal in terms of LUFS for the resulting audio. This is scriptable (with a number of dependencies, like sfizz-render and soz.) I (Jeff Learman) will look into this. Note that this only works for sfz samplesets, but IMHO that's what we should be targeting, using sfizz.
2 Practice
2.1 Roadmap
  6. Editing
  • Issues are being fixed
  • [Common folder structure]
  • [Common controls]
  • [Level matching]
Please note that the purpose of this list is:
  • to collect ideas and as an inspiration for identifying good samplesets of either category
  • to be enhanced, filled and changed by all members
  • not to limit the number of samplesets per instrument type, just add rows as needed.
For "P/W" category, "P" is for "pre-loaded"; "W" is for webconf packages.
Licenses:
  • PD - public domain but not explicitly licensed at the source, for secondary only.
  • Q - questionable or completely undocumented
  • CC license short name
  • GNU GPL & variants
  • Unlicense - specifically using Github or similar Unlicense option, equivalent to CC0
Instrument source license editor size P/S notes
Acoustic Pianos
01 Grand Piano Accurate Salamander Grand v6.2beta2 CC BY jlearman P Lovingly reprocessed Salamander Grand with more even dynamics, and with latency issues fixed. See https://github.com/jlearman/zynthian-salamander-grand for zynthian-ized version.
" Splendid Grand PD jlearman P -
02 Upright Piano - - - - -
03 Felt Piano - - - - -
04 Honkytonk - - - - -
05 Harpsichord - - - - -
Electric Pianos
01 EP Rhodes jRhodes3c CC BY-NC-SA jlearman P "aka Stereo Rhodes." Looped samples. I plan to relax the license to CC BY-SA
" jRhodes3d CC BY-NC jlearman P Unlooped stereo rhodes. I plan some updates.
" current Rhodes sampleset TBD jlearman P -
02 EP Wurlitzer - - - - -
03 EP Hohner Pianet T - - - - -
04 EP Clavinet - - - - -
05 EP CP70 - - - - -
06 Synth Keys - - - - -
07 Sampled Keys - - - - -
Chromatic Percussion
01 Celeste - - - - -
02 Vibraphone VCSL Vibraphone CC-0 ? ? Three articulations (bowed, hard and soft mallet), two velocity layers, sounds great
03 Marimba VCSL Marimba CC-0 ? ? Two velocity layers
" Terkelsen Marimba Q jlearman -
04 Xylophone VCSL Xylophone CC-0 ? ? Three articulations (hard, med, soft mallet), two velocity layers
05 Glockenspiel VCSL Glockenspiel CC-0 ? ? Three velocity layers
06 Steel Drums jSteelDrum Unlicense jlearman P -
07 Kalimba VCSL Kalimba, Kenya CC-0 ? ? Two round robins, there is another Kalimba in the same folder in the repo
08 Music Box - - - - -
10 Dulcimer - - - - -
11 Koto - - - - -
12 Tubular Bell - - - - -
13 Church/Charillon Bell - - - - -
14 Timpani VSCO Timpani CC-0 ? ? 4 Vel-layers, 2 RR
Organs & Reed
01 Drawbar Organ - - - - -
02 Pipe/Church Organ - - - - -
03 Reed Organ - - - - -
04 Harmonium - - - - -
05 Accordion - - - - -
06 Harmonica VCSL Hohner F20 CC-0 ? ? Multiple articulations
07 Melodica - - - - -
08 Bagpipes - - - - -
09 Duduk - - - - -
Synth (might be abandoned in favor for the synth engines)
01 Lead - - - - -
02 Pad - - - - -
03 FM/Keys - - - - -
04 Bass - - - - -
05 String - - - - -
06 Brass - - - - -
07 Organ - - - - -
08 Arp - - - - -
09 Modular - - - - -
10 Theremin - - - - -
Guitar
01 Acoustic Guitar - - - - -
02 Electric Guitar (Clean) - - - - -
03 Electric Guitar (Distorted) - - - - -
04 Jazz Guitar - - - - -
Guitarophone
01 Mandolin - - - - -
02 Ukulele - - - - -
03 Banjo - - - - -
04 Oud - - - - -
05 Lute - - - - -
06 Sitar - - - - -
07 Harp - - - - -
08 Zither - - - - -
09 Shamisen - - - - -
Bass
01 Upright Bass Karoryfer Meatbass CC-0 ? ? Deeply sampled and rounder in sound than the Rubner bass (which is also great)
02 Acoustic Bass - - - - -
03 Electric Bass Karoryfer Black and Blue CC-0 ? ? Deeply sampled
Strings (The majority of the next five sections can be filled with Versilian's VSCO)
01 Violin - - - - -
02 Viola - - - - -
03 Cello - - - - -
04 Double Bass - - - - -
05 Solo Ensemble - - - - -
06 Chamber Ensemble - - - - -
07 Orchestral Ensemble - - - - -
08 Fiddle - - - - -
Brass
02 Flugelhorn - - - - -
03 French Horn - - - - -
04 Trumpet - - - - -
05 Trombone - - - - -
06 Tuba - - - - -
07 Cimbasso - - - - -
08 Solo Ensemble - - - - -
09 Chamber Ensemble - - - - -
10 Orchestral Ensemble - - - - -
11 Soul Brass Trio - - jlearman
Woodwinds
01 Flute - - - - -
02 Oboe - - - - -
03 Bassoon - - - - -
04 English Horn - - - - -
05 Recorder Versilian Recorder CE CC-BY ? ? Has soprano, alto, tenor, bass, greatbass, and contrabass recorder
06 Pan Flute - - - - -
07 Tin Whistle - - - - -
Reeds
01 Soprano Saxophone - - - - -
02 Alto Saxophone - - - - -
03 Tenor Saxophone Karoryfer Weresax CC-0 ? ? -
04 Baritone Saxophone Karoryfer Bearsax CC-0 ? ? -
05 Clarinet - - - - -
06 Bass Clarinet - - - - -
07 Solo Ensemble - - - - -
08 Chamber Ensemble - - - - -
09 Orchestral Ensemble - - - - -
Choirs
01 Solo Voice - - - - -
02 Choir - - - - -
Acoustic Drums
01 Rock - - - - -
02 Jazz Versilian Virtuosity Drums CC-0 ? ? Really great but also really huge. We could make a custom reduced set
03 Brush - - - - -
04 Mallet - - - - -
Electronic Drums
01 808 - - - - -
02 909 - - - - -
03 606 - - - - -
04 LinnDrum - - - - -
05 … - - - - -
Percussion
01 Hand Percussion - - - - -
02 Orchestral Percussion - - - - -
Miscellanious
01 Found Sounds - - - - -
02 Field Recordings - - - - -
03 FX - - - - -
2.4 Changelog/Current edits
