Refactoring Zynthians factory soundfont library
1.2.1.1 Pro own repository
1.2.1.2 Pro pulling upstream
- CC-0: OK. You can do whatever you like with these samples. Because we value intellectual property very much, we'll credit creators and sources anyway. And of course we keep the license file.
- CC-BY: OK. We need to credit the author, which we want to do anyway.
- CC-BY-SA: OK. In my understanding, given ZynthianOS is licensed under GPL-3, the BY-SA is one way compatible to this. So when we credit the author, we're fine.
- CC-BY-NC-SA: OK. In my understanding, the ZynthianOS licensed under GPL-3 independently from the commercial kit being sold, is a non-commercial undertake.
- CC-BY-ND: CRITICAL. We might use this library in unchanged form, which prohibits zynthian specific editing.
- CC BY-NC-ND: CRITICAL. Same as above.
1.4.1 Curating vs. collecting
1.5.2 Level matching?
2 Practice
2.1 Roadmap
- Make decisions concerning the key desing decisions above
- Initiating a publically available github repository based in the existing patches OR create a new blank one only containing folders for categories and edit away
- Drafting the distribution process (including in download image, github pull, webconf package?). Immediate distribution vs. distribution on finishing the project.
- Writing guidelines containing infos on license files, READMEs, target size, target engine, general and category specific common controls and editing notes
- Choosing candidates for including, preferably with CC-0 license
- Editing
- Complying with given license is mandatory. Missing license files are being added from original sources, otherwise soundfont must be dropped. This doesn't apply for missing licenses of the sfz script if that script is obviously trivial (list of regions connecting files with note values). Each Instrument contains a license file regarding samples and scripts and at least a zynthian specific README which can be displayed in the patch selection window. CC-BY-ND licences samples are included by git submodule if it is usable in the recommended soundfont player (i.e. Sfizz)
- Sampleset is usable out of the box by preferred engine (i.e. Sfizz) omiting or replacing opcodes these engines cannot use
- Issues are being fixed
- [Target maximum size and how to achieve it]
- [Limit the number of patches per instrument type?]
- [Unifying multiple files (e.g. articulations) into one]
- [Common folder structure]
- Instrument contains a *.yml file. But for simpler sfz the autogeneration might be sufficient.
- [Common controls]
- [Instrument specific controls]
- [Level matching]
Please note that the purpose of this list is:
- to collect ideas and as an inspiration for identifying good soundfonts of either category
- to be enhanced, filled and changed by all members
- not to limit the number of soundfonts per instrument type. That case just write it into that cell.
Woodwind instrument Availability in VSCO2 CE / SSO / VPO / FreePats Recommended default source Why it wins (for factory use) Key risks / caveats Second choice
| Instrument | source | license | editor | notes |
| Acoustic Pianos | ||||
| 01 Grand Piano | Salamander V3 | - | ||
| 02 Upright Piano | - | - | ||
| 03 Felt Piano | - | - | ||
| 04 Honkytonk | - | - | ||
| 05 Harpsichord | - | - | ||
| Electric Pianos | ||||
| 01 EP Rhodes | - | - | ||
| 02 EP Wurlitzer | - | - | ||
| 03 EP Hohner Pianet T | - | - | ||
| 04 EP Clavinet | - | - | ||
| 05 EP CP70 | - | - | ||
| 06 Synth Keys | - | - | ||
| 07 Sampled Keys | - | - | ||
| Chromatic Percussion | ||||
| 01 Celeste | - | - | ||
| 02 Vibraphone | - | - | ||
| 03 Marimba | - | - | ||
| 04 Xylophone | - | - | ||
| 05 Glockenspiel | - | - | ||
| 06 Steel Drums | - | - | ||
| 07 Kalimba | - | - | ||
| 08 Music Box | - | - | ||
| 10 Dulcimer | - | - | ||
| 11 Koto | - | - | ||
| 12 Tubular Bell | - | - | ||
| 13 Church/Charillon Bell | - | - | ||
| 14 Timpani | - | - | ||
| Organs & Reed | ||||
| 01 Drawbar Organ | - | - | ||
| 02 Pipe/Church Organ | - | - | ||
| 03 Reed Organ | - | - | ||
| 04 Harmonium | - | - | ||
| 05 Accordion | - | - | ||
| 06 Harmonica | - | - | ||
| 07 Melodica | - | - | ||
| 08 Bagpipes | - | - | ||
| 09 Duduk | - | - | ||
| Synth | ||||
| 01 Lead | - | - | ||
| 02 Pad | - | - | ||
| 03 FM/Keys | - | - | ||
| 04 Bass | - | - | ||
| 05 String | - | - | ||
| 06 Brass | - | - | ||
| 07 Organ | - | - | ||
| 08 Arp | - | - | ||
| 09 Modular | - | - | ||
| 10 Theremin | - | - | ||
| Guitar | ||||
| 01 Acoustic Guitar | - | - | ||
| 02 Electric Guitar (Clean) | - | - | ||
| 03 Electric Guitar (Distorted) | - | - | ||
| 04 Jazz Guitar | - | - | ||
| Guitarophone | ||||
| 01 Mandolin | - | - | ||
| 02 Ukulele | - | - | ||
| 03 Banjo | - | - | ||
| 04 Oud | - | - | ||
| 05 Lute | - | - | ||
| 06 Sitar | - | - | ||
| 07 Harp | - | - | ||
| 08 Zither | - | - | ||
| 09 Shamisen | - | - | ||
| Bass | ||||
| 01 Upright Bass | - | - | ||
| 02 Acoustic Bass | - | - | ||
| 03 Electric Bass | - | - | ||
| Strings | ||||
| 01 Violin | - | - | ||
| 02 Viola | - | - | ||
| 03 Cello | - | - | ||
| 04 Double Bass | - | - | ||
| 05 Solo Ensemble | - | - | ||
| 06 Chamber Ensemble | - | - | ||
| 07 Orchestral Ensemble | - | - | ||
| 08 Fiddle | - | - | ||
| Brass | ||||
| 02 Flugelhorn | - | - | ||
| 03 French Horn | - | - | ||
| 04 Trombone | - | - | ||
| 05 Tuba | - | - | ||
| 06 Cimbasso | - | - | ||
| 07 Solo Ensemble | - | - | ||
| 08 Chamber Ensemble | - | - | ||
| 09 Orchestral Ensemble | - | - | ||
| Woodwinds | ||||
| 01 Flute | - | - | ||
| 02 Oboe | - | - | ||
| 03 Bassoon | - | - | ||
| 04 English Horn | - | - | ||
| 05 Recorder | - | - | ||
| 06 Pan Flute | - | - | ||
| 07 Tin Whistle | - | - | ||
| 08 Solo Ensemble | - | - | ||
| 09 Chamber Ensemble | - | - | ||
| 10 Orchestral Ensemble | - | - | ||
| Reeds | ||||
| 01 Soprano Saxophone | - | - | ||
| 02 Alto Saxophone | - | - | ||
| 03 Tenor Saxophone | - | - | ||
| 04 Baritone Saxophone | - | - | ||
| 05 Clarinet | - | - | ||
| 06 Bass Clarinet | - | - | ||
| Choirs | ||||
| 01 Solo Voice | - | - | ||
| 02 Choir | - | - | ||
| Acoustic Drums | ||||
| 01 Rock | - | - | ||
| 02 Jazz | - | - | ||
| 03 Brush | - | - | ||
| 04 Mallet | - | - | ||
| Electronic Drums | ||||
| 01 808 | - | - | ||
| 02 909 | - | - | ||
| 03 606 | - | - | ||
| 04 LinnDrum | - | - | ||
| 05 … | - | - | ||
| Percussion | ||||
| 01 Hand Percussion | - | - | ||
| 02 Orchestral Percussion | - | - | ||
| Miscellanious | ||||
| 01 Found Sounds | - | - | ||
| 02 Field Recordings | - | - | ||
| 03 FX | - | - | ||
