Adding Encoders
1 But what is an encoder?
An Encoder
It is endless.
Nord-modular
Nord-modular-G2
The Zynthian -prototype
A zynthian parameter page
Zynthian v5
2 Soldering?
Soldering
You will need
  1. A soldering iron
  2. A soldering iron stand
  3. Solder
  4. Flux
  5. Good Illumination
  6. Three hands
    1. Holding the Solder
    2. Holding the Soldering Iron
  7. A third hand.
2.1 A Multimeter ?
2.1.1 Voltage
2.1.2 Current
V=IR Voltage (Volts) = Current(Amps) * Resistance (Ohms)
W=VI Power (Watts) = Voltage (Volts) * Current (Amps)
The Maths checks out (fairly closely to an engineering accuracy)
12.27 * 0.460 = 5.6442
And here's the clever bit. A Pi runs from 5V so we can calculate the Current flowing into the Pi by playing with the same equation again.
So the current = 5.64/5 = 1.128 Amps
2.1.4 Resistance
And then we come to
2.1.5 Continuity
Resistance's rougher cousin.
Continuity.
2.1.6 Other things the Meter will measure
Very useful devices.
Soldering
Zynthian Code, obviously.
Zynthian Webconf
Zynthian 23017 wiring
Makes notes!!
3.1.1 Raspberry Pi GPIO Pins
GPIO.setmode(GPIO.BOARD)
GPIO.setmode(GPIO.BCM)
3.1.2 I2C
3.1.3 MCP23017
3.1.3.1 Addressing
3.2 Encoder Pins
3.2.1 A Ground Wire
3.2.2 Encoders A-pins
Make Notes!!
3.2.3 Encoders B-pins
3.2.4 Encoders Switches Pins
From our leader...
These capacitors are not “critical” but “convenient”. They debounce the encoder/switch signal and avoid that software debouncing algorithm consumes “high priority” CPU cycles (ISR). I recommend to use some kind of hardware debouncing circuitry with the encoders and switches, but you can ignore my recommendation and your Zynthian probably will work without problems :wink:
And further...
The debouncing circuit in the kit’s PCb consist of 3 capacitor from the 3 signal encoder pins to ground. For the switch pin 100nF and for the 2 encoder pins, 10nF.
Zynthian S1-S4 Switch config
Zynthian-v3
Zynthian-v4
3.2.5 MCP23017 INT-A Pin
3.2.6 MCP23017 INT-B Pin
3.2.7 Zynaptik Config
3.2.8 ADS1115 I2C Address
3.2.9 MCP4728 I2C Address
The I2C bus allows many devices to be connected to it and communicate. One of these devices is the MCP4728 chip which is a four channel Digital to Analog Converter ( DtoA) which means that control voltages can be generated and controlled by a zynthian parameter or the sequencer and the values used to control an external voltage controlled device. So a zynthian connected foot pedal opening and closing the filter on a separate Eurorack synth via the control voltage input to provide A Wah Wah effect.
4 Which setting do I choose?
Start with custom.
Remember
Make Notes!!
As an interface grows ( when 4 user definable switches were added to V4 we had already moved away from the direct encoder route in favour of a much more efficient way of reading encoders and switches, which passed off some of the effort to another piece of silicon. The MCP23017 16 port I2C multiplexer. This board meant the communication between the Raspberry Pi and this 20 pinned chip could be handled by only a few wires at the Pi end, and a standard form of communication called I2C.
5.1 MCP23017 pins
MCP23017 Left Hand Pins
Pin 1 GPBO 108
Pin 2 GPB1 109
Pin 3 GPB2 110
Pin 4 GPB3 111
Pin 5 GPB4 112
Pin 6 GPB5 113
Pin 7 GPB6 114
Pin 8 GPB7 115
Pin 9 Vdd +V Power
Pin 10 Vss 0V Power
Pin 11 Not Connected
Pin 12 I2C SCK Clock
Pin 13 I2C SDA Data
Pin 14 Not Connected
MCP23017 Pin out
MCP23017 Right Hand Pins
Pin 18 Reset
Pin 19 INT B Set as INT B
Pin 20 INT A Set As INT A
Pin 21 GPA0 100
Pin 22 GPA1 101
Pin 23 GPA2 102
Pin 24 GPA3 103
Pin 25 GPA4 104
Pin 26 GPA5 105
Pin 27 GPA6 106
Pin 28 GPA7 107
Pin 7 - - Pin 8
Pin 9 0v Ground - Pin 10
Pin 11 - - Pin 12
Pin 13 - 0v Ground Pin 14
Pin 15 - - Pin 16
Pin 17 3v3 Power - Pin 18
Pin 19 - 0v Ground Pin 20
Pin 21 - - Pin 22
Pin 23 - - Pin 24
Pin 25 0v Ground - Pin 26
Pin 27 - - Pin 28
Pin 29 - 0v Ground Pin 30
Pin 31 - - Pin 32
Pin 33 - 0v Ground Pin 34
Pin39 0v Ground - Pin 40
5.2.1 MCP23017 I2C Address
Conversely, if you don't see this, then you aren't communicating so you will need to investigate if there is something that is preventing the 12C bus working. It could be a short circuit or a broken wire or perhaps you have got the wires in the wrong order. By and large it's fairly forgiving and you probably haven't damaged anything, just . . .
Make Notes!!
Zynthian-amp3-open
Here's a site devoted to it.
Pi GPIO
6.1.1 Considerations
6.1.2 Pins on the Pi
6.1.2.1 Power Supply
Pin 3 - 5v0 Power Pin 4
Pin 5 - 0v Ground Pin 6
Pin 7 - - Pin 8
Pin 11 - - Pin 12
Pin 15 - - Pin 16
Pin 21 - - Pin 22
Pin 23 - - Pin 24
Pin 27 - - Pin 28
Pin 31 - - Pin 32
Pin 35 - - Pin 36
Pin 37 - - Pin 38
Pin 7 - - Pin 8
Pin 23 - - Pin 24
Pin 31 - - Pin 32
6.1.2.3 General GPIO pins
Pin 3 GPIO 2 5v0 Power Pin 4
Pin 5 GPIO 3 0v Ground Pin 6
Pin 7 GPIO 4 GPIO 14 Pin 8
Pin 11 GPIO 17 GPIO 18 Pin 12
Pin 15 GPIO 22 GPIO 23 Pin 16
Pin 21 GPIO 9 GPIO 25 Pin 22
Pin 23 GPIO 11 GPIO 8 Pin 24
Pin 27 GPIO 0 GPIO 1 Pin 28
Pin 31 GPIO 6 GPIO 12 Pin 32
Pin 35 GPIO 19 GPIO 16 Pin 36
Pin 37 GPIO 26 GPIO 20 Pin 38
6.1.2.4 Specialized GPIO Pins
Pin allocation
A Pins 25 26 4 15
B PINS 27 21 3 7
SWITCH 23 16 2 22
6.1.2.6 Out in the wild
Zynthian-amp3rr
Zynthian-amp3-open
7 Other nefarious methods
4 RGB i2c Encoders and A Blue Pill STM32
