Adding Encoders
1 But what is an encoder?
It is endless.
2 Soldering?
You will need
- A soldering iron
- A soldering iron stand
- Solder
- Flux
- Good Illumination
- Three hands
- Holding the Solder
- Holding the Soldering Iron
- A third hand.
2.1 A Multimeter ?
2.1.1 Voltage
2.1.2 Current
2.1.3 Resistance ! The Next measurement
The Maths checks out (fairly closely to an engineering accuracy)
12.27 * 0.460 = 5.6442
And here's the clever bit. A Pi runs from 5V so we can calculate the Current flowing into the Pi by playing with the same equation again.
So the current = 5.64/5 = 1.128 Amps
2.1.5 Resistance
And then we come to
2.1.6 Continuity
Resistance's rougher cousin.
Continuity.
Very useful devices.
Zynthian Code, obviously.
Do the housekeeping!
Makes notes!!
3.1.1 Raspberry Pi GPIO Pins
GPIO.setmode(GPIO.BOARD)
GPIO.setmode(GPIO.BCM)
3.1.2 I2C
3.1.3 MCP23017
3.1.3.1 Addressing
3.2 Encoder Pins
3.2.1 A Ground Wire
3.2.2 Encoders A-pins
Make Notes!!
3.2.3 Encoders B-pins
3.2.4 Encoders Switches Pins
From our leader...
These capacitors are not “critical” but “convenient”. They debounce the encoder/switch signal and avoid that software debouncing algorithm consumes “high priority” CPU cycles (ISR). I recommend to use some kind of hardware debouncing circuitry with the encoders and switches, but you can ignore my recommendation and your Zynthian probably will work without problems :wink:
And further...
The debouncing circuit in the kit’s PCb consist of 3 capacitor from the 3 signal encoder pins to ground. For the switch pin 100nF and for the 2 encoder pins, 10nF.
3.2.5 MCP23017 INT-A Pin
3.2.6 MCP23017 INT-B Pin
3.2.7 Zynaptik Config
3.2.8 ADS1115 I2C Address
3.2.9 MCP4728 I2C Address
The I2C bus allows many devices to be connected to it and communicate. One of these devices is the MCP4728 chip which is a four channel Digital to Analog Converter ( DtoA) which means that control voltages can be generated and controlled by a zynthian parameter or the sequencer and the values used to control an external voltage controlled device. So a zynthian connected foot pedal opening and closing the filter on a separate Eurorack synth via the control voltage input to provide A Wah Wah effect.
4 Which setting do I choose?
Start with custom.
Remember
Make Notes!!
As an interface grows ( when 4 user definable switches were added to V4 we had already moved away from the direct encoder route in favour of a much more efficient way of reading encoders and switches, which passed off some of the effort to another piece of silicon. The MCP23017 16 port I2C multiplexer. This board meant the communication between the Raspberry Pi and this 20 pinned chip could be handled by only a few wires at the Pi end, and a standard form of communication called I2C.
5.1 MCP23017 pins
| Pin 1 | GPBO | 108 |
| Pin 2 | GPB1 | 109 |
| Pin 3 | GPB2 | 110 |
| Pin 4 | GPB3 | 111 |
| Pin 5 | GPB4 | 112 |
| Pin 6 | GPB5 | 113 |
| Pin 7 | GPB6 | 114 |
| Pin 8 | GPB7 | 115 |
| Pin 9 | Vdd +V Power | |
| Pin 10 | Vss 0V Power | |
| Pin 11 | Not Connected | |
| Pin 12 | I2C SCK Clock | |
| Pin 13 | I2C SDA Data | |
| Pin 14 | Not Connected |
| Pin 18 | Reset | |
| Pin 21 | GPA0 | 100 |
| Pin 22 | GPA1 | 101 |
| Pin 23 | GPA2 | 102 |
| Pin 24 | GPA3 | 103 |
| Pin 25 | GPA4 | 104 |
| Pin 26 | GPA5 | 105 |
| Pin 27 | GPA6 | 106 |
| Pin 28 | GPA7 | 107 |
| Pin 3 | I2C SDA Data Pin | 5v0 Power | Pin 4 |
| Pin 5 | I2C SCL Clock Pin | 0v Ground | Pin 6 |
| Pin 7 | - | - | Pin 8 |
| Pin 11 | - | - | Pin 12 |
| Pin 15 | - | - | Pin 16 |
| Pin 21 | - | - | Pin 22 |
| Pin 23 | - | - | Pin 24 |
| Pin 27 | - | - | Pin 28 |
| Pin 31 | - | - | Pin 32 |
| Pin 35 | - | MCP23017 INT-A Pin | Pin 36 |
| Pin 37 | MCP23017 INT-B Pin | - | Pin 38 |
5.2.1 MCP23017 I2C Address
Once you have this then you can see that your MCP23017 is connected to Address A 0 . The default config. But you can change this if there is a conflict or your MCP23017 board has a different address set up.
Conversely, if you don't see this, then you aren't communicating so you will need to investigate if there is something that is preventing the 12C bus working. It could be a short circuit or a broken wire or perhaps you have got the wires in the wrong order. By and large it's fairly forgiving and you probably haven't damaged anything, just . . .
Make Notes!!
6.1.1 Considerations
6.1.2 Pins on the Pi
6.1.2.1 Power Supply
| Pin 35 | - | - | Pin 36 |
| Pin 37 | - | - | Pin 38 |
| Pin 11 | - | Zynthian Audio Card Pin | Pin 12 |
| Pin 15 | Zynthian Audio Card Pin | Zynthian Audio Card Pin | Pin 16 |
| Pin 17 | 3v3 Power | Zynthian Audio Card Pin | Pin 18 |
| Pin 21 | - | Zynthian Audio Card Pin | Pin 22 |
| Pin 35 | Zynthian Audio Card Pin | - | Pin 36 |
| Pin 37 | Zynthian Audio Card Pin | Zynthian Audio Card Pin | Pin 38 |
| Pin39 | 0v Ground | Zynthian Audio Card Pin | Pin 40 |
6.1.2.3 General GPIO pins
| Pin 27 | GPIO 0 | GPIO 1 | Pin 28 |
6.1.2.4 Specialized GPIO Pins
| A Pins | 25 | 26 | 4 | 15 |
| B PINS | 27 | 21 | 3 | 7 |
| SWITCH | 23 | 16 | 2 | 22 |
6.1.2.6 Out in the wild
7 Other nefarious methods
