Assembling Zynthian Kit V5.1
1.1 BOM V5.1 kit
  • V5.1 Aluminum Case
    • Bottom
    • Top
  • Main Board
  • Control Board
  • Display
  • Raspberry Pi5
  • Thermal Block
  • Silicone Keypad
  • Rubber Feet (4 units)
  • Wiring
  • Screws
  • Allen Spanner 1.5 mm
  • Allen Spanner 2.0 mm
  • 20 x 28 mm
  • 14 x 9 mm
  • 11 x 11 mm
Once you see the splash screen, it could 1-2 minutes to finish the configuration process. You deserve a beer, or at less some tea or coffee. When the first-boot process finishes, the zynthian will reboot and you will be in the main menu, ready to play.
