Assembling Zynthian Kit V5.1
Revision as of 14:52, 9 September 2024 by Jofemodo (talk | contribs) (Created page with "='''Previous Requirements'''= <br clear=all> =='''BOM V5.1 kit'''== <br clear=all> 800px|right * V5.1 Aluminum Case ** Bottom ** Top * Mai...")
1.1 BOM V5.1 kit
  • V5.1 Aluminum Case
    • Bottom
    • Top
  • Main Board
  • Control Board
  • Display
  • Raspberry Pi5
  • Thermal Block
  • Silicone Keypad
  • Rubber Feet (4 units)
  • Wiring
  • Screws
  • Allen Spanner 1.5 mm
  • Allen Spanner 2.0 mm
  • 27 x 20 mm
  • 11 x 11 mm
  • 11 x 9 mm
  • 6 x 6 mm
  • 27 x 20 mm
