Zynthian UI User's Guide - Oram
1.1 How to get started
1.2 Choose your own adventure
1.3 Quick Start
1.4 The Zynthian Project
- Knob#4 is the select knob.
- layer => knob#1
- back => knob#2
- learn/shot => knob#3
- select => knob#4
- SELECT Knob
- short-push to select items.
- BACK Knob
- UP/DOWN:
- LEFT/RIGHT:
- SEL/YES:
- BACK/NO:
- layer
- back
- learn/shot
- select
- S1 => MIDI Program 1
- S2 => MIDI Program 2
- S3 => MIDI Program 3
- S4 => MIDI Program 4
- S1
- long => All Sounds Off
- S2
- short => Zynpad
- bold => Pattern Editor
- S3
- short/bold => Arrow Up
- S4
- short/bold => Arrow Down
- S1
- S1 => CC 47 (value 0/127)
- S2 => CC 48 (value 0/127)
- S3 => CC 49 (value 0/127)
- S4 => CC 50 (value 0/127)
| 1st row: Health & Load | ||
- knob#1
- knob#2
- knob#3
- knob#4
- SEL
- layer
- back
- learn/shot
- select
- create a new chain
- remove an existing chain
- remove all chains
- remove all sequences
- remove all
- Sequencer
- Tempo Settings
- Mixer Learn
- knob#4
- back
- select
- knob#3
- knob#4
- SEL to select a processor.
- knob#3
- knob#4
- back
- learn/shot
- select
- back
- learn/shot
- select
Chain MIDI learning:
Global MIDI learning:
- knob#1 - knob#4
- knob#4
- knob#1 - knob#4
- layer
- back
- learn/shot
- select
- back
- select
- back
- learn/shot
- knob#4
- SEL
- knob#4
- SEL to select/check option.
- back
- select
- back
- select
- knob#4
- SEL
- back
- select
- replace the processor
- remove the processor
- knob#3
- knob#4
- knob#4
- SEL
- back
- learn/shot
- select
- back
- select
- bluetooth MIDI devices
- MIDI network services
- rename the device
- knob#4
- SEL
- knob#4
- SEL
- back
- select
- back
- select
5.12 MIDI Learn
5.13 Audio Out
5.14 Mixer Options
5.15 Processor Options
5.16 Snapshots
5.17 ZS3 (sub-snapshots)
5.18 Confirmation dialog
5.19 On-screen keyboard
5.20 Admin
- the MIDI ins and outs menus
- touchscreen calibration
- power & reboot
5.22 Audio levels
- Access Main Menu.
- The easy way
- The cool way
- knob#4
- knob#3
- knob#2
- knob#1
- Tempo adjustment (BPM)
- Metronome toggle and
- Metronome volume
- Audio record/playback and
- Midi record/playback
| Clock Source Options | |
- REC
- F4 adds a new empty loop
10 CUIA: Callable UI Actions
Interface->UI Key Binding
11 Software Version
11.1 Stable (oram-2506)
11.2 Staging (oram)
11.3 Testing (vangelis)
11.4 Custom
12 Learning Pills
12.2 Basics
12.3 Sequencer
12.4 Mini-HowTos
