Zynthian UI User's Guide - Oram
Revision as of 16:30, 27 October 2025 by Riban (talk | contribs) (Clarification of options/context menu (thanks @jpetso).)
1.1 How to get started
1.2 Choose your own adventure
1.3 Quick Start
1.4 The Zynthian Project
Title Short press Show menu
Title Bold press ZynPad view
Title Long press Admin menu
Chain MIDI learning:
Global MIDI learning:
  • bluetooth MIDI devices
  • MIDI network services
5.12 MIDI Learn
5.13 Audio Out
5.14 Mixer Options
5.15 Processor Options
5.16 Snapshots
5.17 ZS3 (sub-snapshots)
5.18 Confirmation dialog
5.19 On-screen keyboard
5.20 Admin
  • the MIDI ins and outs menus
  • touchscreen calibration
  • power & reboot
5.22 Audio levels
  • Access Main Menu.
  • The easy way
  • The cool way
Arranger View
  • Tempo adjustment (BPM)
  • Metronome toggle and
  • Metronome volume
  • Audio record/playback and
  • Midi record/playback
Clock Source Options
10 CUIA: Callable UI Actions
Interface->UI Key Binding
   ‘i’ is switch 1 (top left).
   ‘o’ is switch 3 (top right).
0x9F  (Channel 16 Note ON)
0x00  (Velocity / parameter)
11 Software Version
11.1 Stable (oram-2506)
11.2 Staging (oram)
11.3 Testing (vangelis)
11.4 Custom
12 Learning Pills
12.2 Basics
12.3 Sequencer
12.4 Mini-HowTos
