Zynthian UI User's Guide - Oram
Revision as of 10:12, 28 May 2025 by Jofemodo (talk | contribs) (→‎Snapshots)
Title Short press Show menu
Title Bold press ZynPad view
Title Long press Admin menu
Chain MIDI learning:
Global MIDI learning:
  • rename the device
  • Access Main Menu.
  • The easy way
  • The cool way
10 Software Version
By default, zynthian runs the stable release, oram-2409.
Any stable point releases are advertised in the user interfaces with an icon showing in the top right. Updates may be applied by selecting 'Update Software' in the admin menu or selecting the SOFTWARE->Update option in webconf, then pressing the 'Update Software' button.
There are four options for selecting which version of zynthian to run. The selection is made in webconf's SOFTWARE->Version page.
Select from the four options in the 'Version' selection box.
10.1 Stable (oram-2409)
10.2 Staging (oram)
10.3 Testing (vangelis)
10.4 Custom
11 Learning Pills
11.1 Basics
11.2 Sequencer
11.3 Mini-HowTos
