Zynthian UI User's Guide - Oram
  • 4 x controller widgets, dynamically assigned to the 4 parameters of the selected page. The controller widgets are layered aside the 4 rotary encoders that can be used for modifying the parameter's value in real time.
Processor parameters can be easily bond to your MIDI controller's knobs & faders (MIDI CC) by using the MIDI learning mechanism:
Chain MIDI learning:
Global MIDI learning:
  • rename the device
  • Access Main Menu.
  • The easy way
  • The cool way
10 Software Version
By default, zynthian runs the stable release, oram-2409.
Any stable point releases are advertised in the user interfaces with an icon showing in the top right. Updates may be applied by selecting 'Update Software' in the admin menu or selecting the SOFTWARE->Update option in webconf, then pressing the 'Update Software' button.
There are four options for selecting which version of zynthian to run. The selection is made in webconf's SOFTWARE->Version page.
Select from the four options in the 'Version' selection box.
10.1 Stable (oram-2409)
10.2 Staging (oram)
10.3 Testing (vangelis)
10.4 Custom
11 Learning Pills
11.1 Basics
11.2 Sequencer
11.3 Mini-HowTos
