Zynthian UI User's Guide - Oram
  • 4 x controller widgets, dynamically assigned to the 4 parameters of the selected page. The controller widgets are layered aside the 4 rotary encoders that can be used for modifying the parameter's value in real time.
Chain MIDI learning:
From the control view, short push the desired parameter (knob). The controller widget will display a green ?? legend. When a parameter is chain-learned, the binding only works when the chain is active. This allow to use the same knobs to control different parameters in different chains.
Global MIDI learning:
From the control view, short push twice the desired parameter (knob). The controller widget will display a yellow ??#?? legend. When a parameter is globally-learned, the binding works all the time, no matter the active chain.
  • rename the device
  • Access Main Menu.
  • The easy way
  • The cool way
10 Software Version
By default, zynthian runs the stable release, oram-2409.
Any stable point releases are advertised in the user interfaces with an icon showing in the top right. Updates may be applied by selecting 'Update Software' in the admin menu or selecting the SOFTWARE->Update option in webconf, then pressing the 'Update Software' button.
There are four options for selecting which version of zynthian to run. The selection is made in webconf's SOFTWARE->Version page.
Select from the four options in the 'Version' selection box.
10.1 Stable (oram-2409)
10.2 Staging (oram)
10.3 Testing (vangelis)
10.4 Custom
11 Learning Pills
11.1 Basics
11.2 Sequencer
11.3 Mini-HowTos
