Zynthian UI User's Guide - Oram
Revision as of 07:47, 27 December 2024 by Riban (talk | contribs) (→‎Software Version)
Title Short press Show menu
Title Bold press ZynPad view
Title Long press Admin menu
  • rename the device
  • Access Main Menu.
  • The easy way
  • The cool way
10 Software Version
By default, zynthian runs the stable release, oram-2409.
Any stable point releases are advertised in the user interfaces with an icon showing in the top right. Updates may be applied by selecting 'Update Software' in the admin menu or selecting the SOFTWARE->Update option in webconf, then pressing the 'Update Software' button.
There are four options for selecting which version of zynthian to run. The selection is made in webconf's SOFTWARE->Version page.
Select from the four options in the 'Version' selection box.
10.1 Stable (oram-2409)
10.2 Staging (oram)
10.3 Testing (vangelis)
10.4 Custom
11 Learning Pills
11.1 Basics
11.2 Sequencer
11.3 Mini-HowTos
