Zynthian UI User's Guide - Oram
Title Short press Show menu
Title Bold press ZynPad view
Title Long press Admin menu
  • rename the device
  • Access Main Menu.
  • The easy way
  • The cool way
10 Software Version
There are four options for selecting which version of zynthian to run. The selection is made in webconf's SOFTWARE->Version page.
Select from the four options in the 'Version' selection box.
10.1 Stable (oram-2409)
10.2 Staging (oram)
10.3 Testing (vangelis)
10.4 Custom
11 Learning Pills
11.1 Basics
11.2 Sequencer
11.3 Mini-HowTos
