Zynthian UI User's Guide - Oram
Title Short press Show menu
Title Bold press ZynPad view
Title Long press Admin menu
  • rename the device
  • Access Main Menu.
  • The easy way
  • The cool way
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
