Zynthian UI User's Guide - Oram
Revision as of 16:41, 2 October 2024 by Jofemodo (talk | contribs) (→‎Introduction)
Zynthian Oram is the last version of zynthianOS, first released in September 2024. It has some substantial changes respect to earlier versions. This user guide describes the core concepts of the system and gives detailed guidance on how to use it. Notice that you can select the documentation for different hardware types (V5, V4, Touch) with the selector in the top right of the page. If you are using V1-V3 then select V4. If you have a custom build then select the version that closest matches your hardware. If your hardware uses features from different official kits then you may wish to check documentation for each hardware type.
It is strongly recommended that you read section 2 on core concepts which explains many aspects of how zynthian works and can provide essential knowledge to improve your understanding and ability to use zynthian. This guide includes details of how to navigate the user interface and some explanation of common workflows. Near the bottom of the guide are links to Learning Pills, short video tutorials that show and describe various workflows. These are short, easily digestible snippets of information that can get you started quickly.
Topbar back button
Title Short press Show menu
Title Bold press ZynPad view
Title Long press Admin menu
  • load/unload drivers
  • rename the device
There is are short, video tutorials demonstrating the creation of chains in the learning pills.
  • Access Main Menu.
  • The easy way
  • The cool way
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
