Zynthian UI User's Guide - Oram
Revision as of 12:58, 2 October 2024 by Riban (talk | contribs) (→‎Presets)
Zynthian Oram is the version of zynthian, first released in September 2024. It has some substantial changes to earlier versions. This user guide describes the core concepts of the system and gives detailed guidance on how to use it. Notice that you can select the documentation for different hardware types (V5, V4, Touch) with the selector in the top right of the page. If you are using V1-V3 then select V4. If you have a custom build then select the version that closest matches your hardware. (If your hardware uses features from different official kits then you may wish to check documentation for each hardware type.) It is strongly recommended that you read section 2 on core concepts which explains many aspects of how zynthian works and can provide essential knowledge to improve your understanding and ability to use zynthian. This guide includes details of how to navigate the user interface and some explaination of common workflows. Near the bottom of the guide are links to Learning Pills, short video tutorials that show and describe various workflows. These are short, easily digestible snippets of information that can get you started quickly.
Topbar back button
Title Short press Show menu
Title Bold press ZynPad view
Title Long press Admin menu
  • load/unload drivers
  • rename the device
See the learning pills.
  • The easy way
    • If you are using ACTIVE mode for your input device, you must enable Active MIDI chanel in the admin menu. With this enabled, all chains in the same MIDI channel will receive the MIDI stream from the input when some of them is selected (active).
    • Setup your "cloned" chains in the same MIDI channel.
  • The cool way
    • If you are using ACTIVE mode for your input device, you must disable Active MIDI chanel in the admin menu. With this disabled, only the selected (active) chain will receive MIDI from the input, not matter the MIDI channel.
    • Setup your ”cloned” chains in the same MIDI channel.
    • Create a MIDI+Audio chain in the same MIDI channel. We name this chain the GROUP chain. You don’t need to add any processor, so you can select None from the list.
    • From the GROUP chain options, access “MIDI out” and select your “cloned” chains. This will route MIDI from the GROIUP chain to the cloned chains.
    • Finally, access Audio Out submenu on each "cloned" chain: uncheck the Main Bus and check the GROUP chain. With this you are routing audio from your cloned chains to the GROUP chain, so you can control de mixed audio with the GROUP’s fader.
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
