Zynthian UI User's Guide - Oram
  Short Push Push and release in less than 0.3 seconds.
  Bold Push Push and hold for longer than 0.3 seconds then release before 2 seconds.
  Long Push Push and hold for longer than 2 seconds. Long-action triggers before release.
  Knob Rotate Rotate the knob.
Title   Show menu
Title   ZynPad view
Title   Admin menu
Topbar back button   Previous view
Topbar back button   Show mixer view
Status Area   Tempo view + Transport control
Status Area   ZS3 menu
Status Area   All notes off (PANIC!)
Solo button   Toggle chain solo
Mute button   Toggle chain mute
Chain Legend   Show chain control view
Chain Legend   Show chain options
Topbar back button   Mixer view
Menu entry   Select menu action
Menu entry   Show context menu for menu entry (if appropriate)
Menu entry   Enter "view-all" mode
Info area   Open the full info view
Topbar back button   Show presets
Controller widget   Toggle MIDI mapping
Controller widget   Show control options menu
Previous chain button   Select previous chain
Show pages button   Show list of pages of controls
Hide sidebar button   Hides the controls to give more space for GUI
Next chain button   Select next chain
  • load/unload drivers
  • rename the device
See the learning pills.
  • The easy way
    • If you are using ACTIVE mode for your input device, you must enable Active MIDI chanel in the admin menu. With this enabled, all chains in the same MIDI channel will receive the MIDI stream from the input when some of them is selected (active).
    • Setup your "cloned" chains in the same MIDI channel.
  • The cool way
    • If you are using ACTIVE mode for your input device, you must disable Active MIDI chanel in the admin menu. With this disabled, only the selected (active) chain will receive MIDI from the input, not matter the MIDI channel.
    • Setup your ”cloned” chains in the same MIDI channel.
    • Create a MIDI+Audio chain in the same MIDI channel. We name this chain the GROUP chain. You don’t need to add any processor, so you can select None from the list.
    • From the GROUP chain options, access “MIDI out” and select your “cloned” chains. This will route MIDI from the GROIUP chain to the cloned chains.
    • Finally, access Audio Out submenu on each "cloned" chain: uncheck the Main Bus and check the GROUP chain. With this you are routing audio from your cloned chains to the GROUP chain, so you can control de mixed audio with the GROUP’s fader.
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
