Zynthian UI User's Guide - Oram
Please bear in mind that in the case of USB connected MIDI devices the learnt settings will apply only to the specific USB Configuration in place at the time of learning. So if you add a USB hub to the rig the ZS3 sub-snapshots won't act.
  Short Push Push and release in less than 0.3 seconds.
  Bold Push Push and hold for longer than 0.3 seconds then release before 2 seconds.
  Long Push Push and hold for longer than 2 seconds. Long-action triggers before release.
  Knob Rotate Rotate the knob.
  • 4 x controller widgets, dynamically assigned to the 4 parameters of the selected page. The controller widgets are layered aside the 4 rotary encoders that can be used for modifying the parameter's value in real time.
  • load/unload drivers
  • rename the device
See the learning pills.
  • The easy way
    • If you are using ACTIVE mode for your input device, you must enable Active MIDI chanel in the admin menu. With this enabled, all chains in the same MIDI channel will receive the MIDI stream from the input when some of them is selected (active).
    • Setup your "cloned" chains in the same MIDI channel.
  • The cool way
    • If you are using ACTIVE mode for your input device, you must disable Active MIDI chanel in the admin menu. With this disabled, only the selected (active) chain will receive MIDI from the input, not matter the MIDI channel.
    • Setup your ”cloned” chains in the same MIDI channel.
    • Create a MIDI+Audio chain in the same MIDI channel. We name this chain the GROUP chain. You don’t need to add any processor, so you can select None from the list.
    • From the GROUP chain options, access “MIDI out” and select your “cloned” chains. This will route MIDI from the GROIUP chain to the cloned chains.
    • Finally, access Audio Out submenu on each "cloned" chain: uncheck the Main Bus and check the GROUP chain. With this you are routing audio from your cloned chains to the GROUP chain, so you can control de mixed audio with the GROUP’s fader.
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
