Zynthian UI User's Guide - Oram
Revision as of 12:20, 9 September 2024 by Jofemodo (talk | contribs) (→‎Basic chain manipulation)
Topbar back button
Title Short press Show menu
Title Bold press ZynPad view
Title Long press Admin menu
Topbar back button Short press Show presets
Controller widget Short press Toggle MIDI mapping
Previous chain button Short press Select previous chain
Show pages button Short press Show list of pages of controls
Hide sidebar button Short press Hides the controls to give more space for GUI
Next chain button Short press Select next chain
  • load/unload drivers
  • rename the device
See the learning pills.
  • The easy way
    • If you are using ACTIVE mode for your input device, you must enable Active MIDI chanel in the admin menu. With this enabled, all chains in the same MIDI channel will receive the MIDI stream from the input when some of them is selected (active).
    • Setup your "cloned" chains in the same MIDI channel.
  • The cool way
    • If you are using ACTIVE mode for your input device, you must disable Active MIDI chanel in the admin menu. With this disabled, only the selected (active) chain will receive MIDI from the input, not matter the MIDI channel.
    • Setup your ”cloned” chains in the same MIDI channel.
    • Create a MIDI+Audio chain in the same MIDI channel. We name this chain the GROUP chain. You don’t need to add any processor, so you can select None from the list.
    • From the GROUP chain options, access “MIDI out” and select your “cloned” chains. This will route MIDI from the GROIUP chain to the cloned chains.
    • Finally, access Audio Out submenu on each "cloned" chain: uncheck the Main Bus and check the GROUP chain. With this you are routing audio from your cloned chains to the GROUP chain, so you can control de mixed audio with the GROUP’s fader.
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
