Zynthian UI User's Guide - Oram
Topbar back button
Title Short press Show menu
Title Bold press ZynPad view
Title Long press Admin menu
Topbar back button Short press Show presets
Controller widget Short press Toggle MIDI mapping
Previous chain button Short press Select previous chain
Show pages button Short press Show list of pages of controls
Hide sidebar button Short press Hides the controls to give more space for GUI
Next chain button Short press Select next chain
  • load/unload drivers
  • rename the device
6.3 Layering chains
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
