Zynthian UI User's Guide - Oram
Revision as of 04:25, 29 August 2024 by Riban (talk | contribs) (Adds touch gestures (need icons))
Horizontal Drag Horizontal Drag Push and drag horizontally. Must release before you can drag vertically.
Vertical Drag Vertical Drag Push and drag vertically. Must release before you can drag horizontally.
2 Finger Horizontal Drag 2 Finger Horizontal Drag Push with 2 fingers and drag horizontally. Must release before you can drag vertically.
2 Finger Vertical Drag 2 Finger Vertical Drag Push with 2 fingers and drag vertically. Must release before you can drag horizontally.
Swipe Horizontally Swipe Horizontally Push, drag horizontally and release whilst still moving.
Swipe Vertically Swipe Vertically Push, drag vertically and release whilst still moving.
Topbar back button
Title Short press Show menu
Title Bold press ZynPad view
Title Long press Admin menu
Status Area Short press Tempo view including transport control
Topbar back button Short press Show presets
Controller widget Short press Toggle MIDI mapping
Previous chain button Short press Select previous chain
Show pages button Short press Show list of pages of controls
Hide sidebar button Short press Hides the controls to give more space for GUI
Next chain button Short press Select next chain
  • load/unload drivers
  • rename the device
6.3 Layering chains
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
