Zynthian UI User's Guide - Oram
Revision as of 07:10, 28 August 2024 by Riban (talk | contribs) (Topbar navigation)
Topbar back button
Title Short press Show menu
Title Bold press ZynPad view
Title Long press Admin menu
Status Area Short press Tempo view including transport control
Topbar Short press Show main menu
Topbar Bold press Show zynpad view
  • load/unload drivers
  • rename the device
6.3 Layering chains
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
