Zynthian UI User's Guide - Oram
Revision as of 07:06, 28 August 2024 by Riban (talk | contribs) (Undo revision 14542 by Riban (talk))
Topbar back button
Title Short press Show menu
Status Area Short press Transport control
Status Area Bold press All notes off (PANIC!)
Topbar Short press Show main menu
Topbar Bold press Show zynpad view
  • load/unload drivers
  • rename the device
6.3 Layering chains
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
