Zynthian UI User's Guide - Oram
Topbar back button
Tapping the title bar will show a context menu if available. Tapping again will show the main menu. Bold press will return to the mixer view.
Title Short press Show menu
Status Area Short press Transport control
Status Area Bold press All notes off (PANIC!)
Topbar Short press Show main menu
Topbar Bold press Show zynpad view
  • load/unload drivers
  • rename the device
6.3 Layering chains
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
