Zynthian UI User's Guide - Oram
Revision as of 15:46, 23 August 2024 by Riban (talk | contribs) (→‎Mixer)
Topbar back button
Title Short press Show menu
Status Area Short press Transport control
Status Area Bold press All notes off (PANIC!)
Topbar Short press Show main menu
  • load/unload drivers
  • rename the device
6.3 Layering chains
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
