Zynthian UI User's Guide - Oram
Topbar back button
Title Short press Show menu
Status Area Short press Transport control
Status Area Bold press All notes off (PANIC!)
Topbar Short press Show main menu
Chain Legend Short press Show control view
Swipe left or right Change the category of engines shown
  • load/unload drivers
  • rename the device
6.3 Layering chains
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
